Samsung C34J791WTU 34" 3440x1440 4ms HDMI LED Monitor
Quicklinx: F5JRWS00 Mfr#: LC34J791WTUXEN
The CJ79 features two Thunderbolt 3 ports to connect compatible Macs and PCs. Thunderbolt 3 transmits video and data at speeds of up to 40 Gbps and simultaneously charges devices (up to 85 W), all over a single cable. The curved screen is engineered to follow the natural curve of your eyes for a more immersive and comfortable viewing experience.
  • Curved for comfort
  • 34" ultra-wide screen
    The 34'' ultra-wide curved display with its 21:9 aspect ratio provides all the workspace you need to multi-task efficiently and in comfort. Forget about inconvenient dual monitor set ups and experience truly seamless multitasking on a single screen.
  • PBP and PIP
    Picture-by-Picture (PBP) lets you display two sources simultaneously at their native resolution. And for optimal multi-tasking, with Picture-in-Picture (PIP) you can resize the second source to up to 25% of the screen and position it anywhere.
  • Quantum Dot Color
    Supporting up to 125% sRGB color space, Quantum Dot technology delivers not only more hues than conventional monitors but also colors that are brighter, crisper, and more natural - especially reds and greens. And every monitor is factory calibrated to ensure the most accurate and life-like images.
  • 3000:1 contrast ratio
    Samsung's VA panel technology provides a 3000:1 contrast ratio that delivers deeper blacks, brilliant whites, and richer colors for clearer, more vibrant images.
  • AMD FreeSync
    AMD FreeSync synchronizes the refresh rates of your graphics card and the CJ79 to minimize image tearing and stutter. The smoother transition between image frames provides seamless gameplay and video playback for uninterrupted viewing.
  • Fast 100 Hz refresh rate
    The fast 100 Hz screen refresh rate provides smoother, silkier mouse sensitivity for enhanced productivity in any application. It also reduces screen stutter in fast-moving action scenes for a flawless gaming experience.
  • Stylish design
    With its curved screen bezel-free on three sides for enhanced viewing and its rear panel - curving horizontally and vertically - neatly concealing cables, the CJ79's slim and striking profile is the perfect complement to any Thunderbolt 3 Mac or PC.
  • Multiple inputs
    Two Thunderbolt 3 ports as well as DP, HDMI and USB inputs of the CJ79 provide multiple connection options for PCs, consoles, and external devices. And the built-in 7-watt stereo speakers offer an enhanced entertainment experiences when viewing videos and playing games.
Samsung C34J791WTU - CJ79 Series - LED monitor - curved - 34"
LED-backlit LCD monitor - 34"
Energy Class
Class G
Power Consumption (On mode)
65 W
Curved Screen
Adaptive-Sync Technology
AMD FreeSync
Daisy Chaining
USB 2.0 hub
Panel Type
VA
Aspect Ratio
21:9
Native Resolution
UWQHD 3440 x 1440 at 100 Hz
Brightness
300 cd/m²
Contrast Ratio
3000:1
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
92%, 125% sRGB, 88% (NTSC 1976), 92% Adobe RGB
Input Connectors
2xThunderbolt 3, HDMI, DisplayPort
Display Position Adjustments
Height, tilt
Voltage
AC 120/230 V
Grey
80.87 cm x 30.94 cm x 51.6 cm
7.7 kg
DisplayPort 1.2
Display Type
Energy Class
Class G
Diagonal Size
34"
Curved Screen
Yes (1500R)
AMD FreeSync
Daisy Chaining
Built-in Devices
USB 2.0 hub
Panel Type
VA
Aspect Ratio
21:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
3000:1
Colour Support
Colour Gamut
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
MagicBright, picture by picture, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, PBP, Factory Calibration, Eco Saving Plus, Eye Saver Mode, Quantum Dot Technology, Picture-in-Picture
Grey
80.87 cm x 30.94 cm x 51.6 cm - with stand
7.7 kg
Audio
Speakers - stereo
Output Power / Channel
7 Watt
DisplayPort , HDMI , Headphones , Thunderbolt 3 (power up to 85W) , Thunderbolt 3 (power up to 15W) , 2 x USB 2.0 downstream
Mechanical
Height, tilt
Tilt Angle
-14/+34
Height Adjustment
100 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable
DisplayPort 1.2
Input Voltage
AC 120/230 V
65 W
65 kWh/1000h
Power Consumption (Off Mode)
0.3 Watt
Included Software
Easy Setting Box
Dimensions & Weight Details
With stand - width: 80.87 cm - depth: 30.94 cm - height: 51.6 cm - weight: 7.7 kg , Without stand - width: 80.87 cm - depth: 16.7 cm - height: 36.28 cm - weight: 6.3 kg
Shipping Width
89.6 cm
Shipping Depth
37.1 cm
Shipping Height
58.9 cm
Shipping Weight
13.9 kg
10 °C
10 - 80% (non-condensing)
