Product
Samsung C34H890WJU 34" 3440x1440 4ms HDMI DP USB-C LED Monitor
With a USB type C port enabling you to transmit power and data easily
Quicklinx: D7DTWS00 Mfr#: LC34H890WJUXEN
Diagonal Size: 34in
Max Resolution: 3440 x 1440
Response Time: 4ms
Speakers: None
Interfaces: DisplayPort, HDMI, USB-C
£521.27 ex VAT
£625.52 inc VAT
The CH89 has a screen resolution of 3440 x 1440 - approximately 2.5 times the pixel density of Full HD - that delivers razor-sharp images. You can see more details at a glance and have a panoptic view of large web pages and documents with less scrolling and zooming.
The 34" ultra-wide curved monitor CH89 is ideal for multi-taskers who need more on-screen space for their big ideas but want to do away with the hassle of dual-monitor setups. With its ultra-wide display you can experience truly seamless single-monitor multitasking.
Samsung's Picture-by- Picture capabilities let you connect to two different devices at the same time while still maintaining the original image quality.
  • Enhanced visual clarity and detail
  • Shake off the dual-monitor inconvenience
  • PBP dual-screen function
  • PIP sub-screen display
    The Picture-in- Picture feature allows you to do away with the need for a second monitor even when you are multitasking. You can resize the second image up to 25% of the screen and position it anywhere you wish.
  • For your viewing comfort
    Engineered to match the natural curvature of the human eye, the CH89 gives you a comfortable and engrossing view of onscreen content. Plus, Samsung's Flicker Free technology and the blue light-reducing Eye Saver Mode add to your visual comfort with reduced eye fatigue.
  • Convenient connectivity - USB type C
    It comes with a USB type C port that enables you to transmit power, data and DisplayPort signals to portable devices like table PCs and PDAs even without a cable connection.
  • Increase your ergonomic efficiency
    It swivels, tilts, and is height-adjustable. VESA-supported, it can be installed on a wall or separate arms with ease. With these functions at your disposal, you can effortlessly position your screen at whatever height and angle you want and share the onscreen content with nearby coworkers.
  • Performance meets beauty
    Slim-bodied and bezel-less on three sides, coming complete with a graceful yet steadfast height-adjustable Y stand, the CH89 is a perfect blend of performance and beauty. Its clean back design incorporates a hatch to keep cables neatly hidden out of sight.
Samsung CH89 Series C34H890WJU - LED monitor - curved - 34"
LED-backlit LCD monitor - 34"
Energy Class
Class B
Energy Consumption per Year
83 kWh
Power Consumption (On mode)
57 W
Curved Screen
Adaptive-Sync Technology
AMD FreeSync
Panel Type
VA
Aspect Ratio
21:9
Native Resolution
3440 x 1440 at 100 Hz
Brightness
300 cd/m²
Contrast Ratio
3000:1
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DisplayPort, USB-C
Display Position Adjustments
Height, swivel, tilt
Dark silver
Display Type
Energy Class
Class B
83 kWh
57 W
Diagonal Size
34"
Curved Screen
Yes (1800R)
AMD FreeSync
Panel Type
VA
Aspect Ratio
21:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
3000:1
Colour Support
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Picture in picture, MagicBright, picture by picture, game mode, Magic Upscale, Flicker Free technology, Eco Saving Plus, Eye Saver Mode, aspect ratio control
Dark silver
USB-C , HDMI , DisplayPort , Headphones , USB
Mechanical
Tilt Angle
-5/+24
Swivel Angle
60
Height Adjustment
135 mm
Flat Panel Mount Interface
100 x 100 mm
1 x HDMI cable , 1 x DisplayPort cable
AC 120/230 V
57 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
10 °C
10 - 80% (non-condensing)
Samsung C34H890WJU 34 Bundle deal on Samsung C34H890WJU 34" 3440x1440 4ms HDMI DP USB-C LED Monitor
£621.03
Diagonal Size: 34in
Response Time: 4ms
Speakers: None
Interfaces: HDMI
Interfaces: USB-C
Brand: Samsung
Price Range Ex VAT: 500 - 750
