Product
Samsung C32H711QEU 32" 2560x1440 4ms HDMI Mini DP Curved LED Monitor
Quicklinx: D7DNWS00 Mfr#: LC32H711QEUXEN
Diagonal Size: 32in
Max Resolution: 2560 x 1440
Response Time: 4ms
Speakers: None
Interfaces: HDMI, Mini DisplayPort
Select:
£377.20 ex VAT
£452.64 inc VAT
Samsung's advanced display delivers richer, more vivid colors bringing movies, sports broadcasts live-streamed gaming and more to life. Multi-coated semiconductor particles ensure long-lasting image quality while Samsung's unique cadmium-free technology is harmless to the environment.
  • Incredible color expression
  • Flicker free
    Samsung's flicker-free technology minimizes distracting screen flicker to let you work and play for longer in greater comfort.
  • 360º design
    The CH711 curved monitor cleverly conceals cables in its rear panel and stand for a stylish look from all sides, while the 3-sided bezeless display enhances its slender profile and offers a seamless viewing experience.
  • Smoother gaming
    You'll enjoy flawlessly smooth gameplay in any kind of action. And game mode lets you effortlessly select screen settings optimized for different game genres to ensure you see darker areas in more the detail in game scenes.
Samsung CH71 Series C32H711QEU - QLED monitor - curved - 32"
QLED monitor - 32"
Energy Class
Class B
Energy Consumption per Year
80 kWh
Power Consumption (On mode)
55 W
Curved Screen
Adaptive-Sync Technology
AMD FreeSync
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
WQHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.2767 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
Display Position Adjustments
Tilt
White
71.25 cm x 27.63 cm x 51.9 cm
6.8 kg
Plug and Play, DDC-2B, EMI, ISO 9241-307 Class 2
2 years warranty
Display Type
QLED monitor / TFT active matrix
Energy Class
Class B
80 kWh
55 W
Diagonal Size
32"
Viewable Size
31.5"
Curved Screen
Yes (1800R)
AMD FreeSync
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2767 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1
Colour Support
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
MagicBright, game mode, Mega Dynamic Contrast Ratio, Eco Saving, Flicker Free technology, Eye Saver Mode, Quantum Dot Technology
White
71.25 cm x 27.63 cm x 51.9 cm - with stand
6.8 kg
HDMI , Mini DisplayPort
Mechanical
Tilt
Tilt Angle
-2/+15
360° rotation
1 x HDMI cable
AC 120/230 V
59 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 71.25 cm - depth: 27.63 cm - height: 51.9 cm - weight: 6.8 kg , Without stand - width: 71.25 cm - depth: 6.28 cm - height: 42.07 cm - weight: 5.3 kg
Limited warranty - 2 years - on-site
10 °C
10 - 80% (non-condensing)
Samsung C32H711QEU 32 Bundle deal on Samsung C32H711QEU 32" 2560x1440 4ms HDMI Mini DP Curved LED Monitor
£476.96
Diagonal Size: 32in
Response Time: 4ms
Speakers: None
Interfaces: HDMI
Interfaces: Mini DisplayPort
Brand: Samsung
Price Range Ex VAT: 300 - 500
