Samsung C27H580F 27" 1920x1080 4ms VGA HDMI DP C-VA LED Curved Monitor
Quicklinx: D7DJWS00 Mfr#: LC27H580FDUXEN
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: None
Interfaces: DisplayPort, HDMI, VGA (HD-15)
More than 50 in stock
£189.97 ex VAT
£227.96 inc VAT
Samsung C27H580FDU - CH58 Series - LED monitor - curved - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
51 kWh
Power Consumption (On mode)
35 W
Curved Screen
Adaptive-Sync Technology
AMD FreeSync
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
3000:1
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Blue black
61.42 cm x 27.04 cm x 45.73 cm
4.2 kg
Environmental Standards
ENERGY STAR Qualified
Display Type
Energy Class
Class B
51 kWh
35 W
Diagonal Size
27"
Viewable Size
27"
Curved Screen
Yes (1800R)
AMD FreeSync
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
3000:1
Colour Support
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
MagicBright, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Safe, Image Size, Eco Saving Plus, Eye Saver Mode, Active Crystal Color, 119.3% sRGB colour gamut, 88.4% Adobe RGB colour gamut, 80.6% (CIE 1976) colour gamut
Blue black
61.42 cm x 27.04 cm x 45.73 cm - with stand
4.2 kg
HDMI , VGA , DisplayPort , Headphones , Audio line-in
Mechanical
Tilt
Tilt Angle
-2/+20
1 x HDMI cable
35 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Drivers & Utilities
Dimensions & Weight Details
With stand - width: 61.42 cm - depth: 27.04 cm - height: 45.73 cm - weight: 4.2 kg , Without stand - width: 61.42 cm - depth: 14.29 cm - height: 26.29 cm - weight: 3.3 kg
ENERGY STAR Certified
10 °C
10 - 80%
Samsung C27H580F 27 Bundle deal on Samsung C27H580F 27" 1920x1080 4ms VGA HDMI DP C-VA LED Curved Monitor
£289.14
Diagonal Size: 27in
Response Time: 4ms
Speakers: None
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Samsung
Price Range Ex VAT: 150 - 300
