Product
Brand
Samsung C27FG70FQU 27" 1920X1080 1ms HDMI DP LED Monitor
Quicklinx: D7DVWS00 Mfr#: LC27FG70FQUXEN
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 1ms
Speakers: None
Interfaces: DisplayPort, HDMI
30 in stock
£335.76 ex VAT
£402.91 inc VAT
Samsung's CFG7 series expresses brilliant colors, while employing an environmentally-safe cadmium-free design. This luminance emphasizes a range of otherwise-hidden game details in both light and dark settings, offering superb visual realism designed to capture the attention of even hardcore gamers.
Samsung CFG7 Series C27FG70FQU - LED monitor - curved - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
55 kWh
Power Consumption (On mode)
38 W
Curved Screen
Adaptive-Sync Technology
AMD FreeSync
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 144 Hz
Brightness
350 cd/m²
Contrast Ratio
3000:1
Response Time
1 ms
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Matte dark blue black
62.12 cm x 38.64 cm x 55.06 cm
6.2 kg
Display Type
Energy Class
Class B
55 kWh
38 W
Diagonal Size
27"
Curved Screen
Yes (1800R)
AMD FreeSync
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
350 cd/m²
Contrast Ratio
3000:1
Colour Support
Response Time
1 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Picture Mode, Black eQualizer, On-screen Digital Controls, Flicker Free technology, Eco Saving Plus, Eye Saver Mode, FreeSync Technology, Quantum Dot Technology, Super Arena Gaming UX
62.12 cm x 38.64 cm x 55.06 cm - with stand
6.2 kg
DisplayPort , 2 x HDMI , Headphones
Mechanical
Tilt Angle
-2/+17
Swivel Angle
30
Height Adjustment
140 mm
Flat Panel Mount Interface
75 x 75 mm
Dual Hinge stand
1 x HDMI cable , 1 x DisplayPort cable
79 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Windows 10
Dimensions & Weight Details
With stand - width: 62.12 cm - depth: 38.64 cm - height: 55.06 cm - weight: 6.2 kg , Without stand - width: 62.12 cm - depth: 9.17 cm - height: 36.69 cm - weight: 4.1 kg
10 °C
Diagonal Size: 27in
Response Time: 1ms
Speakers: None
Interfaces: HDMI
Brand: Samsung
Price Range Ex VAT: 300 - 500
