Samsung Black 46" 1080 Full HD LED Large Format Display
Quicklinx: CW38WS00 Mfr#: LH46UDEHLBB/EN
TV Tuner Presence: No
Video Interface: HDMI
  • 1080p (Full HD)
£1,974.98 ex VAT
£2,369.97 inc VAT
Samsung's UDE-A Series SMART Signage video walls enable businesses to manage and showcase rich visual content easily and effectively. Optimized for indoor retail, corporate and public applications, Samsung's professional-grade video walls revolutionize the large-scale display viewing experience by delivering compelling content with consistently accurate color and superior picture quality. By combining the benefits of Samsung's professional-grade digital signage with a distraction-free picture, narrow bezel and enhanced display panel technology, Samsung's UDE-A video walls enable seamless delivery of digital content for superior informational and promotional impact.
  • Designed for 24/7 operation
    Communicate with customers 24/7 thanks to increased durability and reliability.
  • 700nit brightness
    700-nit brightness allows you to broadcast vivid, highly legible images and visual messaging in a range of lighting conditions.
  • Ultra narrow bezel
    The ultra narrow bezel creates a virtually uninterrupted viewing experience to keep audiences focused on content rather than the display itself.
  • Advanced factory calibration
    Any irregularity in brightness and color accuracy will impact the video wall viewing experience. To eliminate these types of color expression inconsistencies, Samsung's UDE Series video walls feature advanced factory tuning and innovative hardware. After calibration, these displays offer an industry-leading local uniformity of more than 90 percent across a 5x5 grid of each display screen, which translates into uniform color expression across the entire display setup.
  • Free color calibration software
    Users can manage brightness and color uniformity conveniently with Samsung's powerful free software, Samsung Color Expert. This advanced color management solution ensures superior uniformity and consistency of color expression, making UDE Series video walls ideal for large-scale presentations.
  • Superior panel quality
    UDE-A's V-PID panel ensures superior display quality by preventing panel blackening even after long periods of use. Additionally, these panels undergo rigorous pre-calibration to guarantee your content is captivating and distraction-free.
  • Easy UHD content on large video walls
    As the industry's first video wall to be equipped with an integrated DisplayPort (DP) 1.2 and HDMI ports, Samsung UDE-A screens can display Ultra-High Definition (UHD) content across video wall configurations as large as 5x5 without requiring expensive external repeating devices.
  • Direct LED (d-LED) BLU (backlight unit) with backlight dimming
    Delivers vivid color expression while reducing power consumption.
Samsung UD46E-A UDE-A Series - 46" LED display
LED-backlit LCD flat panel display
Diagonal Class
46"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight
TV Tuner
No tuner
Commercial Features
Button lock, SMART Signage Platform, Image Rotation, Auto Source Switching & Recovery
Settings Cloning Capability
Remote Control
Standard remote
Voltage
Energy Class
Class D
187 Watt
Power Consumption (On mode)
168 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
245 kWh
102.21 cm x 9.74 cm x 57.66 cm
16.2 kg
Environmental Standards
ENERGY STAR Qualified
Energy Class
Class D
187 Watt
168 W
245 kWh
Diagonal Class
46"
Commercial Use
Series
UDE-A Series
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Temperature sensor
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
HDCP Compatible
Dimensions
Without stand
102.21 cm
9.74 cm
57.66 cm
16.2 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
LED backlight
Colour Depth
16.7 million colours
Image Contrast Ratio
3500:1
Dynamic Contrast Ratio
10000:1
Brightness
700 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.53025 x 0.53025mm
Response Time
8 ms
Commercial Features
Pivot, Multiple Display Control (MDC), Advanced Color Management, 10 x10 Daisy-Chain support, d-LED DID
Stands & Mounts
Stand
Optional
VESA Mounting Interface
600 x 400 mm
Remote Control
Standard remote
Connector Type
VGA input , DVI-D input , DisplayPort input , DisplayPort output , 2 x HDMI input , Audio line-in , Audio line-out , Multiple Display Control , Serial input , Serial output
Batteries
DisplayPort cable
Plug and Play, CSA, UL, TUV, VCCI, C-Tick, BSMI, GOST, DDC-2B, EN55022, NEMKO, NOM, PCBC, SASO, SIQ, EN55024, CISPR 22, CCC, PSB, AS/NZS 3548, FCC, IRAM, UL 60950-1, IEC 60950-1, EN 60950-1, KCC, CSA C22.2 No. 60950-1, FCC Part 15 B Class A, VCCI V-3, KC, GB 9254-2008, KN22, KN24, K60950-1, GB4943.1-2011, CNS 13438, GB 17625.1-2012, NOM-019-SCFI-1993
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
0.5 Watt
Power Consumption (Off Mode)
0 Watt
Width (Shipping)
116 cm
Depth (Shipping)
28 cm
Height (Shipping)
71.5 cm
Weight (Shipping)
22.6 kg
10 - 80% (non-condensing)
Brand: Samsung
Price Range Ex VAT: 1500+
