Samsung AS-17 Clear Cover
Quicklinx: CXWQWS00 Mfr#: EF-QA320TTEGWW
Samsung Samsung AS-17 Clear Cover
  • Invincibly invisible
    Featuring a shell-type design for maximum durability, enhanced device safeguarding gives you just the peace of mind you need to keep typing without any worry.
  • Handle with confidence
    Supremely comfortable in the hand, its slim shape and contoured design makes for easier control and added protection. So inconspicuous you won't even know you have it on.
Samsung Clear Cover EF-QA320 - back cover for mobile phone
Back cover for mobile phone
6.821 cm x 0.915 cm x 13.743 cm
13.6 g
Transparent
Galaxy A3 (2017)
6.821 cm
0.915 cm
13.743 cm
13.6 g
Transparent
Carrying Case
Protective cover
Recommended Use
For mobile phone
Cover Type
Back cover
Samsung Galaxy A3 (2017)
