Product
Samsung A5-17 Clear Cover
Quicklinx: CXWYWS00 Mfr#: EF-QA520TTEGWW
Its transparent casing molds perfectly to the contours of your device without obscuring its signature design. And thanks to its soft textured finish it grips great in the hand.
Samsung Clear Cover EF-QA520 - back cover for mobile phone
Back cover for mobile phone
7.348 cm x 0.915 cm x 14.817 cm
15.2 g
Transparent
Galaxy A5 (2017)
7.348 cm
0.915 cm
14.817 cm
15.2 g
Transparent
Carrying Case
Protective cover
Recommended Use
For mobile phone
Cover Type
Back cover
Samsung Galaxy A5 (2017)
