Samsung 970 EVO Plus 500GB M.2 SSD
Quicklinx: F1C2WS00 Mfr#: MZ-V7S500BW
Form Factor: M.2 2280
Capacity: 500GB, 500GB
Interface: PCI Express 3.0 x4 (NVMe)
Type: Internal hard drive
Hurry, only 2 left in stock!
£94.55 ex VAT
£113.46 inc VAT
Unreal Performance, Realized.
Always Evolving SSD
The ultimate in performance, upgraded. Faster than the 970 EVO, the 970 EVO Plus is powered by the latest V-NAND technology and firmware optimization. It maximizes the potential of NVMe bandwidth for unbeatable computing. In capacities up to 2TB, with reliability of up to 1,200 TBW.
Level up Performance
The 970 EVO Plus reaches sequential read/write speeds up to 3,500/3,300 MB/s, up to 53% faster than the 970 EVO. The latest V-NAND—which brings greater NAND performance and higher power efficiency—along with optimized firmware, a proven Phoenix controller, and Intelligent TurboWrite boost.
Unparalleled Reliability
Achieve a new level of drive confidence. Samsung’s advanced nickel-coated controller and heat spreader on the 970 EVO Plus enable superior heat dissipation. The Dynamic Thermal Guard automatically monitors and maintains optimal operating temperatures to minimize performance drops.
  • Level up performance
    Samsung's V-NAND technology - which brings greater NAND performance and higher power efficiency - along with optimized firmware, a proven Phoenix controller, and Intelligent TurboWrite boost speeds.
  • Design flexibility
    The 970 EVO Plus fits high capacity onto the compact M.2 (2280) form factor, greatly expanding storage capacity and saving space for other components. Samsung's innovative technology empowers you with the capacity to do more and accomplish more.
  • Unparalleled reliability
    Achieve a new level of drive confidence. Samsung's advanced nickel-coated controller and heat spreader on the 970 EVO Plus enable remarkable heat dissipation. The Dynamic Thermal Guard automatically monitors and maintains optimal operating temperatures to help minimize performance drops.
Samsung 970 EVO Plus MZ-V75S500BW - solid state drive - 500 GB - PCI Express 3.0 x4 (NVMe)
Solid state drive - internal - TRIM support, sleep mode, Auto Garbage Collection Algorithm, V-NAND Technology, NVM Express (NVMe) 1.3, Samsung Phoenix Controller
500 GB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
Triple-level cell (TLC)
M.2 2280
Buffer Size
512 MB
TRIM support, sleep mode, Auto Garbage Collection Algorithm, V-NAND Technology, NVM Express (NVMe) 1.3, Samsung Phoenix Controller, S.M.A.R.T.
22.15 mm x 80.15 mm x 2.38 mm
8 g
5-year warranty
500 GB
Hardware Encryption
256-bit AES
M.2 2280
Buffer Size
512 MB
22.15 mm
80.15 mm
2.38 mm
8 g
Performance
SSD Endurance
300 TB
Internal Data Rate
3500 MBps (read) / 3200 MBps (write)
4KB Random Read
19000 IOPS
4KB Random Write
60000 IOPS
Maximum 4KB Random Write
550000 IOPS
Maximum 4KB Random Read
480000 IOPS
Reliability
MTBF
1,500,000 hours
Expansion & Connectivity
PCI Express 3.0 x4 (NVMe) - M.2 Card
Compatible Bay
M.2 2280
Power Consumption
5.8 Watt (average) , 9 Watt (maximum) , 30 mW (idle max)
IEEE 1667
Limited warranty - 5 years
70 °C
Shock Tolerance (operating)
1500 g @ 0.5 ms half-sine
Capacity: 500GB
Capacity: 500GB
Brand: Samsung
Price Range Ex VAT: 50 - 100
