Samsung 970 EVO Plus 2TB M.2 SSD
Quicklinx: F1C4WS00 Mfr#: MZ-V7S2T0BW
Form Factor: M.2 2280
Capacity: 2TB, 2TB
Interface: PCI Express 3.0 x4 (NVMe)
Type: Internal hard drive
£345.65 ex VAT
£414.78 inc VAT
Unreal Performance, Realized.
Always Evolving SSD
The ultimate in performance, upgraded. Faster than the 970 EVO, the 970 EVO Plus is powered by the latest V-NAND technology and firmware optimization. It maximizes the potential of NVMe bandwidth for unbeatable computing. In capacities up to 2TB, with reliability of up to 1,200 TBW.
Level up Performance
The 970 EVO Plus reaches sequential read/write speeds up to 3,500/3,300 MB/s, up to 53% faster than the 970 EVO. The latest V-NAND—which brings greater NAND performance and higher power efficiency—along with optimized firmware, a proven Phoenix controller, and Intelligent TurboWrite boost.
Unparalleled Reliability
Achieve a new level of drive confidence. Samsung’s advanced nickel-coated controller and heat spreader on the 970 EVO Plus enable superior heat dissipation. The Dynamic Thermal Guard automatically monitors and maintains optimal operating temperatures to minimize performance drops.
  • Level up performance
    The 970 EVO Plus reaches sequential read/write speeds up to 3,500/3,300 MB/s, up to 53% faster than the 970 EVO. The latest V-NAND - which brings greater NAND performance and higher power efficiency - along with optimized firmware, a proven Phoenix controller, and Intelligent TurboWrite boost.
  • Design flexibility
    The next advancement in NVMe SSD. The 970 EVO Plus fits up to 2TB onto the compact M.2 (2280) form factor, greatly expanding storage capacity and saving space for other components. Samsung's innovative technology empowers you with the capacity to do more and accomplish more.
  • Exceptional endurance
    The new standard in sustainable performance. The 970 EVO Plus provides exceptional endurance powered by the latest V-NAND technology and Samsung's quality.
  • Unparalleled reliability
    Achieve a new level of drive confidence. Samsung's advanced nickel-coated controller and heat spreader on the 970 EVO Plus enable superior heat dissipation. The Dynamic Thermal Guard automatically monitors and maintains optimal operating temperatures to minimize performance drops.
  • Samsung Magician
    Advanced drive management made simple. The Samsung Magician software will help you keep an eye on your drive. A suite of user-friendly tools helps keep your drive up to date, monitor drive health and speed, and even boost performance.
Samsung 970 EVO Plus MZ-V7S2T0BW - solid state drive - 2 TB - PCI Express 3.0 x4 (NVMe)
Solid state drive - internal - RAPID mode support, V-NAND Technology, eDrive, NVM Express (NVMe) 1.3, Samsung Phoenix Controller
2 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
Triple-level cell (TLC)
M.2 2280
Buffer Size
2 GB
22.15 mm x 80.15 mm x 2.38 mm
8 g
5-year warranty
2 TB
Hardware Encryption
256-bit AES
M.2 2280
Buffer Size
2 GB
22.15 mm
80.15 mm
2.38 mm
8 g
Performance
SSD Endurance
1200 TB
Internal Data Rate
3500 MBps (read) / 3300 MBps (write)
4KB Random Read
19000 IOPS
4KB Random Write
60000 IOPS
Maximum 4KB Random Write
560000 IOPS
Maximum 4KB Random Read
620000 IOPS
Expansion & Connectivity
PCI Express 3.0 x4 (NVMe) - M.2 Card
Compatible Bay
M.2 2280
IEEE 1667
Limited warranty - 5 years
Capacity: 2TB
Capacity: 2TB
Brand: Samsung
Price Range Ex VAT: 300 - 500
