Samsung 960GB 983DCT M.2 NVMe SSD
Quicklinx: F8JRWS00 Mfr#: MZ-1LB960NE
Samsung's 983 DCT is a high-performance solution for servers that need enhanced data reliability to safeguard critical data, from content delivery networks (CDNs) to big data, artificial intelligence (AI) and Internet of Things (IoT) applications. Available in two form factors, U.2 and M.2., the 983 DCT's NVMe interface empowers blazing-fast speed, high responsiveness and a high Quality of Service (QoS).
Samsung 983 DCT MZ-1LB960NE - SSD - 960 GB - PCIe 3.0 x4 (NVMe)
Solid state drive - internal
960 GB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
3D triple-level cell (TLC)
M.2 22110
PCIe 3.0 x4 (NVMe)
Buffer Size
1.5 GB
TRIM support, Auto Garbage Collection Algorithm, Enterprise Power-Loss Protection, Advanced ECC Engine, Samsung Phoenix Controller, S.M.A.R.T.
22 mm x 110.02 mm x 3.8 mm
20 g
5-year warranty
960 GB
Hardware Encryption
256-bit AES
M.2 22110
PCIe 3.0 x4 (NVMe)
Buffer Size
1.5 GB
22 mm
110.02 mm
3.8 mm
20 g
Performance
SSD Endurance
1366 TB
Internal Data Rate
3000 MBps (read) / 1100 MBps (write)
Maximum 4KB Random Write
38000 IOPS
Maximum 4KB Random Read
400000 IOPS
Reliability
MTBF
2,000,000 hours
Expansion & Connectivity
1 x PCI Express 3.0 x4 (NVMe) - M.2 Card
Compatible Bay
M.2 22110
Power Consumption
7.5 Watt (read) , 7.2 Watt (write) , 2.6 Watt (idle max)
Software Included
Samsung SSD Magician DC
Limited warranty - 5 years
70 °C
Shock Tolerance (operating)
1500 g @ 0.5 ms half-sine
