Experience incredible performance, designed for heavy workloads and demanding applications with the high-capacity, highly reliable Samsung 960 PRO hard drive. Ideal for advanced PCs and workstations, the 960 PRO boasts an amazing 48-layer Samsung V-NAND-based architecture, that delivers excellent performance in a compact M.2 form factor.
- Samsung 960 PRO MZ-V6P512BW - solid state drive - 512 GB - PCI Express 3.0 x4 (NVMe)
- Solid state drive - internal
- Capacity
- 512 GB
- Hardware Encryption
- Encryption Algorithm
- 256-bit AES
- NAND Flash Memory Type
- Multi-level cell (MLC)
- Form Factor
- M.2 2280
- Interface
- TRIM support, sleep mode, Auto Garbage Collection Algorithm, TurboWrite Technology, V-NAND Technology, eDrive, NVM Express (NVMe), S.M.A.R.T., 256-bit AES, IEEE 1667
- 22.1 mm x 80.01 mm x 2.29 mm
- 9 g
- 5 years warranty
- Capacity
- 512 GB
- 256-bit AES
- Form Factor
- M.2 2280
- Interface
- 22.1 mm
- 80.01 mm
- 2.29 mm
- 9 g
Performance
- SSD Endurance
- 400 TB
- Internal Data Rate
- 3500 MBps (read) / 2100 MBps (write)
- Maximum 4KB Random Write
- 330000 IOPS
- Maximum 4KB Random Read
- 330000 IOPS
Reliability
- MTBF
- 1,500,000 hours
Expansion & Connectivity
- 1 x PCI Express 3.0 x4 (NVMe) - M.2 Card
- Compatible Bay
- M.2 2280
- Power Consumption
- 1.2 Watt (idle) , 5.1 Watt (average) , 5 mW (sleep)
- Software Included
- Samsung Magician Software
- Limited warranty - 5 years
- 0 °C
- 70 °C
- Shock Tolerance (non-operating)
- 1500 g @ 0.5 ms
