Product
Samsung 850 PRO 2TB Basic SATA 6Gb/s 2.5" Solid State Drive
Quicklinx: BHNLWS00 Mfr#: MZ-7KE2T0BW
Samsung's flash memory is fabricated using an excellent 3D V-NAND architecture, which stacks 32 cell layers on top of one another rather than trying to decrease the cells' length and width to fit today's shrinking form factors. The result is higher density and higher performance using a smaller footprint and a breakthrough in overcoming the density limits of conventional planar NAND architecture. The result - enhanced performance, lower power consumption with an up to 1 GB LPDDR2 DRAM cache memory and improved energy-efficiency with the 3-core MEX controller.
  • Boost performance with an excellent 3D V-NAND SSD
    Powered by Samsung's cutting-edge 3D V-NAND technology, the NAND flash memory delivers the ultimate in read and writes performance in both sequential and random aspects. This is especially impressive in the 128 GB model that outperforms similar models on the market by more than 100 MB/s in write speed.
  • Shift into high gear with the enhanced RAPID mode
    You can kick up the read/write performance on every capacity when you need it with the RAPID mode. Just like shifting gears in a car, Magician software gives you the option to enhance performance by processing data on a system level using free PC memory (DRAM) as a cache, providing 1.8 times faster performance in the RAPID mode.
  • Work longer with high-efficiency innovation
    The efficient, power management components in the 850 PRO enable you work longer and more productively. Boasting the lowest power consumption of any SSD when in full use, the 850 PRO expends less energy while maintaining performance. The 850 PRO fully supports the sleep mode on the Ultrabook, consuming only 2 m watts of power. Plus, its LPDDR2 cache memory provides higher performance while consuming 30 percent less power when active and 93 percent less power when idle than typical DDR2 or DDR3 memory.
  • Safeguard precious data without sacrificing performance
    Protect your PC's hardware and personal data when you take your laptop on the road with the 850 PRO's SED technology. The drive includes an AES-256-bit hardware-based, full disk encryption engine that secures your data without performance degradation, often experienced with software-based encryption. The 850 PRO's advanced security complies with the TCG Opal v2.0 standards, protecting PSID, and is compatible with the Microsoft eDrive IEEE 1667 protocol. Plus, you can erase or initialize data with the crypto erase service.
  • Protect your PC from overheating with Dynamic Thermal Guard protection
    The 850 PRO includes Dynamic Thermal Guard protection, which keeps your PC performance safe from overheating. Dynamic Thermal Guard protection monitors and maintains the drive's optimal operating temperature with a throttle feature that automatically drops the SSD's temperature when necessary to protect your data and ensure the responsiveness you expect.
  • Ensure each component works together seamlessly
    Samsung is one of the few manufacturers that actually design all the SSD components in-house and has the most experience in the SSD market. Because Samsung has intimate knowledge of every component and its parts, it can fine-tune them at each stage of development to ensure they work together beautifully.
Samsung 850 PRO MZ-7KE2T0BW - solid state drive - 2 TB - SATA 6Gb/s
Solid state drive - internal
2 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
Multi-level cell (MLC)
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
2 GB
Hardware Full Disk Encryption (FDE), TRIM support, Garbage Collection technology, DevSleep mode, 3D V-NAND Technology, RAPID mode support, Samsung MHX Controller, Low Power DDR3 SDRAM Cache, S.M.A.R.T., 256-bit AES, IEEE 1667
69.85 mm x 100 mm x 6.8 mm
66 g
10 years warranty
2 TB
Hardware Encryption
256-bit AES
2.5"
SATA 6Gb/s
Buffer Size
2 GB
69.85 mm
100 mm
6.8 mm
66 g
Performance
SSD Endurance
300 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
550 MBps (read) / 520 MBps (write)
Maximum 4KB Random Write
90000 IOPS
Maximum 4KB Random Read
100000 IOPS
Reliability
MTBF
2,000,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Power Consumption
3.3 Watt (read) , 3.4 Watt (write) , 60 mW (idle) , 5 mW (sleep)
Software Included
Samsung Magician Software, Samsung Data Migration
Limited warranty - 10 years
70 °C
5 - 95% (non-condensing)
Shock Tolerance (non-operating)
1500 g @ 0.5 ms
Vibration Tolerance (non-operating)
20 g @ 20-2000 Hz
