This 8-channel DVR package includes 4 weather-resistant, 720 TVL resolution cameras that deliver true daylight color and clear night vision up to 82 ft. The system is easily customized for advanced monitoring and notification options.
Anytime/Anywhere
Samsung's free iPOLis mobile app brings surveillance video right to your iOS or Android tablet or smartphone. To oversee multiple systems in various locations, Samsung's central management software, Smart Viewer, allows video monitoring from all points around the globe on a single screen.
Event/Tampering Alerts
Instant email notifications can be sent when motion or camera tampering is detected and automatically recorded onto the DVR. Guarding your safety, Samsung empowers you to respond instantly to unexpected events, view real-time activity and review stored recordings.
Sharp, Rich Details
The cameras provide up to 720 TVL resolution for clear, vivid image quality. In keeping with this high standard, the DVR records at 960H high resolution onto a 500 GB hard drive to capture all of your important video events.
Wide Angle Coverage
While other cameras constrict your view, Samsung's 72 Wide Angle lens expands your recording coverage without compromising quality.
True Day & Night
Each SDS-P4042 camera utilizes an advanced IR Cut Filter for accurate, vibrant colors and Night Vision mode to capture clear, illuminated footage up to 82 feet in darkness.
Privacy Masking
Privacy Masking allows you to block up to four areas within each camera's field of view. This advantage lets you tailor your monitoring to exclude sensitive areas or conceal irrelevant or personal activity.
Weather-Resistant
Every camera in the SDS-P4042 system has achieved an Ingress Protection Rating of IP66. Rest assured that they have been tested to withstand dust, wind and rain.
Easy Setup/Upgrade
DVR setup is intuitive and simple and can accommodate four additional cameras. Samsung's optional WiFi adapter eliminates the need for network cable connection. This liberates DVR placement away from the router to your most suitable location within WiFi range.
Box Contains
DVR (SDR-4102)
Camera (SDC-7340BC) 4pcs
Remote Control / Battery / Mouse
Adapter / Power Cord
60ft BNC Camera Cable 4pcs
CD (Smart Viewer, User Manual)
Quick Guide / Network Cable
HDMI Cable
Event & tampering notification
Instant email notifications can be sent when motion is detected or when cameras are redirected, vandalized or covered - and the activity is automatically recorded onto the DVR. Bringing your safety to the forefront, Samsung empowers you to respond instantly to unexpected events, view real-time activity and review stored recordings. -
Clear, vivid high definition quality
The SDS-P4042 cameras capture video at 720 TVL of resolution for the highest level of image quality. In keeping with this high standard, the DVR records at 960H high definition, surpassing both the D1 (720) and CIF (360) formats common to inferior systems. The 500 GB surveillance class rated hard drive will capture all of your important video events so they're there when you need them. Samsung sets its sights on exceeding your visual expectations. -
Wide angle coverage
While other cameras constrict your view, Samsung's 72° Wide Angle lens expands your recording coverage without compromising quality. -
True day & night/night vision
Each SDS-P4042 camera utilizes an advanced IR Cut Filter for accurate, vibrant colors and a night vision mode to capture clear, illuminated footage up to 82 feet. -
Privacy masking
The system's Privacy masking feature allows you to block up to four areas within each camera's field of view. This advantage lets you tailor your monitoring to fit your specific needs and eliminate motion detection and false notifications in areas that are not significant to your security or safety. It also plays a part in economizing video storage space. -
IP66 weatherproof cameras
Every camera in the SDS-P4042 system has achieved an Ingress Protection Rating of IP66. Rest assured that they have been tested to withstand dust, wind and rain. -
Easy setup and upgrade
The SDS-P4042 DVR setup is intuitive and simple. Samsung's optional Wi-Fi adapter eliminates the need for network cable connection. This liberates DVR placement away from the router to your most suitable home or business location within Wi-Fi range. The cameras' easy-to-install ball joint mounts and cable-through design make installation a snap and your cable secure from tampering.
- SAMSUNG TECHWIN SDS-P4042 - DVR + camera(s)
- System
- DVR + camera(s)
- Security DVR
- 8 channels
- Hard Drive
- 1 x 500 GB
- Camera
- 4 cameras - outdoor - PAL - night vision
- 31.5 cm x 22.4 cm x 5.2 cm
- 1.56 kg
- System
- DVR + camera(s)
- Package Content
- 4 cameras, DVR, manual, remote control, mouse, power adapter
- Cables Included
- Camera cable - BNC - 18.3 m - 4 pcs. , Network cable - 1 pcs. , HDMI cable - 1 pcs.
- Software Included (Y)
- Drivers & Utilities, Samsung Smart Viewer
Security DVR
- Video Channels
- 8
- Frame Rate (Playback)
- 200 fps (PAL)
- Frame Rate (Record)
- 200 fps (PAL)
- Image Resolution
- 720x576 (PAL), 704x576 (PAL), 352x288 (PAL), 704x288 (PAL), 960x576 (PAL)
- Compression Format
- G.711, H.264
- Record Events
- Alarm, motion detection, scheduled, event, manual, continuous, tamper detection, time lapse, video loss
- Watermark, picture-in-picture (PIP), password protection, e-mail alarm notifications, SmartViewer, Webviewer, Mobile Viewer, 960H Technology
Hard Drive
- Quantity Installed
- 1
- Capacity
- 500 GB
- Interface
- Serial ATA
Cameras
- Quantity
- 4 cameras
- Camera Type
- Outdoor
- Sensor
- CMOS - 1/3" - 976x582
- Field of View
- 60° (H), 48° (V)
- Horizontal Resolution (TV Lines)
- 700
- Scanning System
- Interlace
- TV System
- PAL
- Sensitivity (lux)
- 0
- Night Vision
- Infrared LEDs
- Infrared Distance
- 25 m
- Signal-To-Noise Ratio
- 46 dB
- White Balance
- Auto
- Gain Control
- Auto
- Focal Length
- 3.8 mm
- Voltage
- DC 12 V
- Power Consumption
- 3 Watt
- -10 °C
- 50 °C
- Operating Humidity
- 20-85%
- IP66
- Video Input Ports
- BNC x 8
- Video Output Ports
- HDMI x 1, VGA x 1
- Audio Input Ports
- RCA x 4
- Audio Output Ports
- RCA x 1
- Network Port
- 10/100Base-T
- Other Ports
- USB 2.0 x 2, eSATA x 1, serial RS-485 x 1
- 31.5 cm
- 22.4 cm
- 5.2 cm
- 1.56 kg
- Details
- Camera: 7.21 cm x 19.24 cm x 6.29 cm - 252 g , DVR: 31.5 cm x 22.4 cm x 5.2 cm - 1.56 kg
