Expand your storage with a compact fit designed to plug in and stay. Read speeds up to 300 MB/s with the USB 3.1 standard.
Plug in and stay
Designed to plug in and stay. Expand your storage with the FIT Plus, a compact flash drive, seamless and unobtrusive. Instant storage for your laptops, tablets, TV's, car audio systems, gaming consoles, and more. -
Store more, leave it in
Extra storage in a seamlessly fitting design. Leave it in your devices with reduced risks of accidental bumps or removal. Enough capacity for your favorite tunes, irreplaceable photos / videos, important work documents, and personal files. -
Quick and convenient
Save time, add space. Quick and convenient read speeds up to 300 MB/s with the USB 3.1 standard to ensure transferring data never slows you down. Send a 3 GB 4K UHD video file from your FIT Plus to your PC in just 10 seconds. -
Tough & trusted
Files stay secure, anywhere you go. It works through it all with a waterproof, shock-proof, temperature-proof, magnet-proof, and X-ray-proof body.
- Samsung FIT Plus MUF-64AB - USB flash drive - 64 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.1
- Storage Capacity
- 64 GB
- 5-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 64 GB
- Compatibility
- Non-specific
- Read Rate
- Up to 200 MB/s
- Interface Type
- USB 3.1
- Shockproof, magnetic-proof, waterproof, X-ray-proof, temperature-proof, key ring loop
- Limited warranty - 5 years
- 23.6 mm
- 7.3 mm
- 18.8 mm
- 3.1 g
- -25 °C
- 85 °C
