Samsung 64GB Fit Plus USB 3.1 Drive - Up to 200MB/s
Quicklinx: DRNTWS00 Mfr#: MUF-64AB/EU
Capacity: 64GB
Interface: USB 3.1
£13.67 ex VAT
£16.40 inc VAT
Expand your storage with a compact fit designed to plug in and stay. Read speeds up to 300 MB/s with the USB 3.1 standard.
  • Plug in and stay
    Designed to plug in and stay. Expand your storage with the FIT Plus, a compact flash drive, seamless and unobtrusive. Instant storage for your laptops, tablets, TV's, car audio systems, gaming consoles, and more.
  • Store more, leave it in
    Extra storage in a seamlessly fitting design. Leave it in your devices with reduced risks of accidental bumps or removal. Enough capacity for your favorite tunes, irreplaceable photos / videos, important work documents, and personal files.
  • Quick and convenient
    Save time, add space. Quick and convenient read speeds up to 300 MB/s with the USB 3.1 standard to ensure transferring data never slows you down. Send a 3 GB 4K UHD video file from your FIT Plus to your PC in just 10 seconds.
  • Tough & trusted
    Files stay secure, anywhere you go. It works through it all with a waterproof, shock-proof, temperature-proof, magnet-proof, and X-ray-proof body.
Samsung FIT Plus MUF-64AB - USB flash drive - 64 GB
USB flash drive
Interface Type
USB 3.1
Storage Capacity
64 GB
5-year warranty
USB flash drive
Storage Capacity
64 GB
Compatibility
Non-specific
Read Rate
Up to 200 MB/s
Interface Type
USB 3.1
Shockproof, magnetic-proof, waterproof, X-ray-proof, temperature-proof, key ring loop
Limited warranty - 5 years
23.6 mm
7.3 mm
18.8 mm
3.1 g
-25 °C
85 °C
Capacity: 64GB
Interface: USB 3.1
Brand: Samsung
Price Range Ex VAT: 0 - 50
