Boasting of slim depth design, Samsung's PMF series standalone displays provide a compact, but strong signage solution for environments limited by space or configuration. These standalone displays feature a narrow-bezel configuration to further maintain viewers' focus aimed at on-screen content. The standalone displays' integrated centralized infrared receiver (IR) ensures easier and more flexible user control. All models can receive the IR signal on individual panels via Central IR. Through tailored installation or mounting, users can navigate the IR functionality from various locations, further augmenting uninterrupted performance. Equipped with a non-glare frontal panel, the PMF series displays reduce natural and ambient light interference to ensure continuous readability in any location. Image visibility and information readability are deemed to be very high, because it is less reflective under light or sunlight, which poses no issues when used with QSR menu boards, or airport flight schedule boards with ample natural light.
Discover displays that break the previous limits of slim design
Boasting of slim depth design, Samsung's PMF series standalone displays provide a compact, but strong signage solution for environments limited by space or configuration. These standalone displays feature a narrow-bezel configuration to further maintain viewers' focus aimed at on-screen content. -
Unlock easier and more flexible control due to a centralized infrared receiver
The standalone displays' integrated centralized infrared receiver (IR) ensures easier and more flexible user control. All models can receive the IR signal on individual panels via Central IR. Through tailored installation or mounting, users can navigate the IR functionality from various locations, further augmenting uninterrupted performance. -
Bring an end to unwanted glare and always be assured of high visibility and readability
- Samsung PM55F PMF Series - 55" LED-backlit LCD display - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 55"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Frame Rate & Enhancement Technology
- 60 Hz Refresh Rate
- Max Number of Screens
- 225
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- Wi-Fi
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- LCD Backlight Technology
- Edge-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- Button lock, HTML5 support, Auto Source Switching & Recovery
- Speaker System
- 2 speakers
- USB
- 2 ports
- Included Accessories
- Remote control, batteries
- Energy Class
- Class A
- 187 Watt
- Power Consumption (On mode)
- 115 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 160 kWh
- Dimensions (WxDxH) - without stand
- 122.84 cm x 2.99 cm x 70.12 cm
- 16.3 kg
- Product Type
- Energy Class
- Class A
- 187 Watt
- 115 W
- 160 kWh
- Diagonal Class
- 55"
- Commercial Use
- Series
- PMF Series
- Operating System
- Tizen OS
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Temperature sensor
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- Modes
- Portrait mode, landscape mode
- Design
- Narrow Bezel Design, swivel screen
- Protection
- Dustproof
- Dimensions
- Without stand
- 122.84 cm
- 2.99 cm
- 70.12 cm
- 16.3 kg
Display
- Resolution
- 1920 x 1080
- 16:9
- Edge-lit LED
- Image Contrast Ratio
- 5000:1
- Brightness
- 500 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 8 ms
- Multiple Display Control (MDC), Certified for 24/7 Continuous Operation, MagicInfo, USB Cloning, Mega Dynamic Contrast Ratio, SSSP 4.0, Center IR
Video Wall
- 225
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 400 x 400 mm
Media Player
- USB Port
- USB Ports Qty
- 2
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Connectivity
- Wi-Fi
- Connector Type
- 2 x HDMI , 2 x USB 2.0 , DVI-I , Audio line-in , Audio line-out , DisplayPort input , DisplayPort output , Multiple Display Control , Serial input , Serial output
- Batteries
- Cables Included
- Serial adapter
- Plug and Play, CSA, UL, TUV, VCCI, C-Tick, BSMI, GOST, cUL, NEMKO, NOM, SASO, CB, AS/NZS 60950-1, CCC, PSB, IRAM, EN 60950-1, FCC Part 15 B Class A, KC, GB 9254-2008, NOM-019-SCFI-1998, KN22, KN24, K60950-1, cUL No.60950-1, EAC, RCM, IP5X, IS13252, VCCI V-3/2010.04 Class A, CNS 14972, GOST-R 51317 series, GOST 22505-97, CNS 13438 Class A ITE EMI, CNS 13439 AV EMI, CNS 14409 AV EMS, GB 17625.1-2012, NOM-001-SCFI-1993, BIS, INMETRO, IEC60950-1, GB 4943.1-2011, CE/EMC, AS/NZS CISPR 22:2009, KCC/EK, EN 55024:1998+A1:2001+A2:2003, EN 55022:2006+A1:2007
- Power Device
- Power supply
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- 0 Watt
- Width (Shipping)
- 133.5 cm
- Depth (Shipping)
- 18.2 cm
- Height (Shipping)
- 81.2 cm
- Weight (Shipping)
- 21.8 kg
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
