Product
Samsung 55" Black LED Large Format Display Full HD
Quicklinx: CTRGWS00 Mfr#: LH55PMFPBGC/EN
TV Tuner Presence: No
Video Interface: HDMI
  • 1080p (Full HD)
£2,037.51 ex VAT
£2,445.01 inc VAT
Boasting of slim depth design, Samsung's PMF series standalone displays provide a compact, but strong signage solution for environments limited by space or configuration. These standalone displays feature a narrow-bezel configuration to further maintain viewers' focus aimed at on-screen content. The standalone displays' integrated centralized infrared receiver (IR) ensures easier and more flexible user control. All models can receive the IR signal on individual panels via Central IR. Through tailored installation or mounting, users can navigate the IR functionality from various locations, further augmenting uninterrupted performance. Equipped with a non-glare frontal panel, the PMF series displays reduce natural and ambient light interference to ensure continuous readability in any location. Image visibility and information readability are deemed to be very high, because it is less reflective under light or sunlight, which poses no issues when used with QSR menu boards, or airport flight schedule boards with ample natural light.
  • Discover displays that break the previous limits of slim design
  • Unlock easier and more flexible control due to a centralized infrared receiver
  • Bring an end to unwanted glare and always be assured of high visibility and readability
Samsung PM55F PMF Series - 55" LED display
LED-backlit LCD flat panel display
Diagonal Class
55"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Motion Enhancement Technology
60 Hz Refresh Rate
Video Wall Components Qty
225
Video Interface
HDMI
HDMI Ports Qty
2 ports
Wi-Fi
PC Interface
DVI, VGA (HD-15), DisplayPort
LCD Backlight Technology
LED backlight - edge-lit
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Button lock, HTML5 support, Auto Source Switching & Recovery
Speaker System
2 speakers
USB
2 ports
Remote Control
Standard remote
Energy Class
Class A
187 Watt
Power Consumption (On mode)
115 W
Energy Consumption per Year
160 kWh
122.84 cm x 2.99 cm x 70.12 cm
16.3 kg
Energy Class
Class A
187 Watt
115 W
160 kWh
Diagonal Class
55"
Commercial Use
Series
PMF Series
TV Tuner
No tuner
Sensors
Temperature sensor
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
Modes
Portrait mode, landscape mode
Design
Narrow Bezel Design, swivel screen
Protection
Dustproof
225
Dimensions
Without stand
122.84 cm
2.99 cm
70.12 cm
16.3 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
60 Hz Refresh Rate
Image Contrast Ratio
5000:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Commercial Features
Multiple Display Control (MDC), Certified for 24/7 Continuous Operation, MagicInfo, USB Cloning, Mega Dynamic Contrast Ratio, SSSP 4.0, Center IR
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Media Player
USB Port
USB Ports Qty
2
Operating System
Tizen OS
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
Wi-Fi
Connector Type
2 x HDMI , 2 x USB 2.0 , DVI-I , Audio line-in , Audio line-out , DisplayPort input , DisplayPort output , Multiple Display Control , Serial input , Serial output
Batteries
Serial adapter
Plug and Play, CSA, UL, TUV, VCCI, C-Tick, BSMI, GOST, cUL, NEMKO, NOM, SASO, CB, AS/NZS 60950-1, CCC, PSB, IRAM, EN 60950-1, FCC Part 15 B Class A, KC, GB 9254-2008, NOM-019-SCFI-1998, KN22, KN24, K60950-1, cUL No.60950-1, EAC, GB4943.1-2011, RCM, IP5X, EN55024:1998 + A1:2001 + A2:2003, IS13252, VCCI V-3/2010.04 Class A, CNS 14972, AS/NZS CISPR22:2009, GOST-R 51317 series, GOST 22505-97, EN55022:2006 + A1:2007, CNS 13438 Class A ITE EMI, CNS 13439 AV EMI, CNS 14409 AV EMS, GB 17625.1-2012, NOM-001-SCFI-1993, BIS, INMETRO, IEC60950-1, CE/EMC, KCC/EK
Power supply
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0 Watt
Width (Shipping)
133.5 cm
Depth (Shipping)
18.2 cm
Height (Shipping)
81.2 cm
Weight (Shipping)
21.8 kg
10 - 80% (non-condensing)
Brand: Samsung
Price Range Ex VAT: 1500+
