Samsung 55" Black, LED Large Format Display, Full HD, 500 cd/m2, 24/
Quicklinx: D4NVWS00 Mfr#: LH55PMHPBGC/EN
  • 1080p
Samsung's PMH series premium displays achieve peak performance all while maintaining a stylish and captivating design. The PMH series displays leverage elevated brightness and refined image sharpness to ensure a consistently clear presentation even in settings with variable lighting. Additionally, the PMH series displays achieve robust, 24/7 durability for dependable and uninterrupted operations. As a result, businesses can feel confident that their messages will be delivered exactly as intended anywhere and at any time.
  • Put your worries to rest knowing that your display is protected from a range of environmental conditions
    PMH standalone displays feature dust-resistant design and ability to withstand a range of environmental conditions. Uninterrupted, 24/7 content delivery is always assured regardless of surrounding natural or interactive conditions.
  • Brilliant, glare-free visual quality
    Equipped with a non-glare frontal panel, the PMH series displays reduce natural and ambient light interference to ensure continuous readability in any location. Image visibility and information readability are deemed to be very high, because it is less reflective under light or sunlight, which poses no issues when used with QSR menu boards, or airport flight schedule boards with ample natural light.
Samsung PM55H PMH Series - 55" LED-backlit LCD display - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
55"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Video Interface
HDMI
HDMI Ports Qty
2 ports
Wi-Fi, LAN
PC Interface
DVI, DisplayPort
LCD Backlight Technology
Edge-lit LED
Image Aspect Ratio
16:9
Picture Enhancements
Mega Dynamic Contrast Ratio
USB
2 ports
Voltage
AC 120/230 V
Energy Class
Class A
187 Watt
Power Consumption (On mode)
115 W
Power Consumption Stand by
0.4 Watt
Energy Consumption per Year
160 kWh
123.24 cm x 3.05 cm x 70.12 cm
16.5 kg
Energy Class
Class A
187 Watt
115 W
160 kWh
Diagonal Class
55"
Commercial Use
Series
PMH Series
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, DisplayPort
Dimensions
Without stand
123.24 cm
3.05 cm
70.12 cm
16.5 kg
Display
Resolution
1920 x 1080
Image Aspect Ratio
16:9
Edge-lit LED
Coating
25% Glass Haze
Image Contrast Ratio
4000:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
6 ms
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Media Player
USB Port
USB Ports Qty
2
Network & Internet Multimedia
Wi-Fi, LAN
Connector Type
2 x HDMI , DisplayPort input , DVI-Digital , 2 x USB , Audio line-in , Audio line-out , Serial input , Serial output , 2 x LAN
EMC Class A
Power supply
Input Voltage
AC 120/230 V
0.4 Watt
Width (Shipping)
138.3 cm
Depth (Shipping)
16 cm
Height (Shipping)
81.9 cm
Weight (Shipping)
21.1 kg
10 - 80% (non-condensing)
