If you're a heavy workload professional searching for an SSD with uncompromising power and performance, look no further. The next-generation Samsung 950 PRO delivers exceptional performance for professionals.
This cutting-edge V-NAND-based NVMe SSD supports PCI Express Gen 3 x 4 lanes, providing a higher bandwidth and lower latency to process a massive amount more data than SATA SSDs.
Presented in a compact M.2 form factor, the future-oriented 950 PRO is ideal for professionals using high-end PCs and workstations.
Experience a next-generation SSD today
Equipped with the enhanced bandwidth of the NVMe interface, the 950 PRO is ideal for intensive workloads, such as computer-aided design, data analysis and engineering simulations. It outperforms SATA SSDs by over 4,5 times in sequential read and by over 2.5 times in sequential write, delivering the speeds of 2500 MB/s and 1500 MB/s respectively. -
Save power while maintaining peak performance
If you're in the midst of performing a complex data analysis or engineering simulation on your laptop, you surely don't want to run out your battery. Compared to SATA SSD power consumption, the 950 PRO is up to 1,5 times more power efficient, so your battery will last longer and maintain superior performance levels. -
Maximize endurance under heavy workloads
The innovative V-NAND technology in the 950 PRO increases endurance and prolongs the lifespan with insulators that cause less stress and are more resistant to wear under heavy client workloads over a 5-year period. The 950 PRO also features Dynamic Thermal Throttling Protection technology, which controls the temperature of the device to reduce overheating and maintain a high level of sustained performance.
- Samsung 950 PRO MZ-V5P512BW - SSD - 512 GB - PCIe 3.0 x4 (NVMe)
- Solid state drive - internal
- Capacity
- 512 GB
- Hardware Encryption
- Encryption Algorithm
- 256-bit AES
- Form Factor
- M.2 2280
- Interface
- Buffer Size
- 512 MB
- TRIM support, sleep mode, Thermal throttling, Auto Garbage Collection Algorithm, Low Power DDR3 SDRAM Cache, S.M.A.R.T., 256-bit AES, IEEE 1667
- 22.15 mm x 80.15 mm x 2.38 mm
- 10 g
- 5-year warranty
- Capacity
- 512 GB
- 256-bit AES
- Form Factor
- M.2 2280
- Interface
- Buffer Size
- 512 MB
- 22.15 mm
- 80.15 mm
- 2.38 mm
- 10 g
Performance
- SSD Endurance
- 400 TB
- Internal Data Rate
- 2500 MBps (read) / 1500 MBps (write)
- Maximum 4KB Random Write
- 110000 IOPS
- Maximum 4KB Random Read
- 300000 IOPS
Reliability
- MTBF
- 1,500,000 hours
Expansion & Connectivity
- 1 x PCI Express 3.0 x4 (NVMe) - M.2 Card
- Compatible Bay
- M.2 2280
- Power Consumption
- 5.7 Watt (average) , 7 Watt (maximum)
- Software Included
- Samsung Magician Software
- Limited warranty - 5 years
- 0 °C
- 70 °C
- Shock Tolerance (non-operating)
- 1500 g @ 0.5 ms
