Samsung 512GB 840 Pro Series SATA 6Gb/s 2.5" Solid State Drive
Quicklinx: 8BNTWS00 Mfr#: MZ-7PD512BW
The Samsung 840 PRO is a high performance SSD designed for power users. Capable of delivering up to 100,000 IOPS Random Read Speed and 540MB/s Sequential Read speed, it is an SSD of unrivaled high performance. Even better, the advanced MDX controller delivers these speeds regardless of data type, unlike some competing controllers that greatly favor compressible data.
  • Capacity: 512GB
  • Sequential Read: 540MB/s
  • Sequential Write: 520MB/s
  • Random Read (QD32, 4KB): 100,000 IOPS
  • Random Write (QD32, 4KB): 90,000 IOPS
  • Random Read (QD1, 4KB): 9,900 IOPS
  • Random Write (QD1, 4KB): 31,000 IOPS
  • Active Power Use: 0.068W (down from 0.24W for 830 Series)
  • Idle Power Use: 0.042W (down from 0.14W for 830 Series)
  • Warranty: 5 Year
  • Unrivaled performance
    Samsung's SSD 840 PRO Series is a high-performance SSD, capable of delivering up to 100,000 IOPS random read speed and 540 MB/s sequential read speed - an SSD of unrivaled high performance. Built with an advanced MDX controller, Samsung's SSD delivers high speeds regardless of data type, unlike competing controllers that greatly favor compressible data.
  • Superior reliability
    The Samsung SSD 840 Series is optimized for exceptional, sustained performance and unrivaled reliability through its specially-engineered wear-leveling and garbage collection algorithms.
  • Performance sustainability
    The Samsung SSD 840 PRO Series provides the same excellent performance throughout its entire lifetime even under extremely heavy workloads. In fact, the sophisticated MDX controller is capable of maintaining peak performances under punishing conditions for more than twice as long the nearest competitor.
  • Business friendly features
    The 840 SSD 840 PRO Series features three important hardware features for businesses: Worldwide Name (WWN), LED Indicator support, and AES 256-bit Full Disk Encryption (FDE). The first two features make it easier to integrate the 840 PRO SSD into server and storage systems while the AES Encryption helps safeguard data against attack. By encrypting all information on the disk at the hardware level, there is no detrimental effect on performance.
Samsung 840 Pro Series MZ-7PD512 - solid state drive - 512 GB - SATA 6Gb/s
Solid state drive - internal
512 GB
Hardware Encryption
2.5" Ultra Slim Line
SATA 6Gb/s
Data Transfer Rate
600 MBps
Hardware Full Disk Encryption (FDE), TRIM support, Garbage Collection technology, Samsung 3-core MDX Controller, Samsung Toggle DDR2 NAND Flash memory, S.M.A.R.T., 256-bit AES
69.85 mm x 100 mm x 7 mm
68 g
5 years warranty
512 GB
Hardware Encryption
SATA 6Gb/s
69.85 mm
100 mm
7 mm
68 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
540 MBps (read) / 520 MBps (write)
4KB Random Read
100000 IOPS
4KB Random Write
90000 IOPS
Reliability
MTBF
1,500,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
Software Included
Drivers & Utilities, Samsung Magician Software, Samsung Smart Migration Software
Linux, Apple MacOS X, Microsoft Windows XP SP2 or later, Microsoft Windows Server 2003 x64 Edition SP2 or later, Microsoft Windows Server 2003 SP2 or later, Microsoft Windows Vista SP1 or later, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits)
TAA Compliant
Limited warranty - 5 years
60 °C
5 - 95% (non-condensing)
Shock Tolerance
1500 g @ 0.5ms (non-operating)
Vibration Tolerance
2.17 g @ 7-800 Hz (operating) / 3.08 g @ 7-800 Hz (non-operating)
Resources
The following resources are available for the Samsung 512GB 840 Pro Series SATA 6Gb/s 2.5" Solid State Drive
