Samsung 500GB Portable SSD X5 Thunderbolt 3
Quicklinx: DRP3WS00 Mfr#: MU-PB500B/EU
Form Factor: 2.5"
Capacity: 500GB, 500GB
Interface: Thunderbolt 3
Type: External hard drive
Select:
£188.87 ex VAT
£226.64 inc VAT
Samsung Portable SSD X5
Professionalism at its finest
Elevate your storage tasks to ultimate heights on PCs and Macs with Thunderboltâ„¢ 3 ports. The X5 is designed for tech savvy professionals who want to render or compile high resolution contents faster than ever. Its thermal management and password protection offer both comfort and security.
Wield the power of Thunderboltâ„¢ 3
Thunderbolt 3 and NVMe Interface
The X5 is here to quench your thirst for advanced technology. Thunderbolt 3 delivers the fastest bandwidth up to 40 Gb/s that brings lightning speed and performance. Equipped with the astonishing speed of NVMe interface, the X5 assists with handling heavier data at faster speeds.
  • Wield the power of Thunderbolt 3
    The X5 is here to quench your thirst for advanced technology. Thunderbolt 3 brings lightning speed and performance.
  • Built to be cool and durable
    Never worry about heat. The X5's DTG technology helps maintain optimal performance and temperature, and a heat sink keeps surface temperature controlled. Its body has no moving parts and is reinforced with magnesium alloy that can even withstand drops.
Samsung X5 Portable MU-PB500B - solid state drive - 500 GB - Thunderbolt 3
Solid state drive - external (portable) - Dynamic Thermal Guard protection, NVM Express (NVMe)
500 GB
Hardware Encryption
Encryption Algorithm
256-bit AES
Thunderbolt 3 - USB-C
Data Transfer Rate
40 Gbps (Thunderbolt 3)
Dynamic Thermal Guard protection, NVM Express (NVMe), 256-bit AES
Power Source
Thunderbolt bus
Enclosure Colour
Grey
11.9 cm x 1.97 cm x 6.2 cm
150 g
3-year warranty
500 GB
Hardware Encryption
256-bit AES
Thunderbolt 3
Internal Drive Interface
PCI Express 3.0 x4 (NVMe)
11.9 cm
1.97 cm
6.2 cm
150 g
Performance
Interface Transfer Rate
Max Data Transfer Rate
2800 MB/s
Data Transfer Rate Details
Thunderbolt 3 (read): 2800 MB/s , Thunderbolt 3 (write): 2100 MB/s
Expansion & Connectivity
1 x Thunderbolt 3
Power Source
Thunderbolt bus
UL, TUV, VCCI, C-Tick, BSMI, CB, IC, FCC, KC, EAC
Enclosure Colour
Grey
Limited warranty - 3 years
Form Factor: 2.5"
Capacity: 500GB
Capacity: 500GB
Brand: Samsung
Price Range Ex VAT: 150 - 300
