Achieve the ultimate read/write performance to maximize your everyday computing experience with Samsung's TurboWrite technology. You not only obtain more than a 10% better user experience but up to 1.9x faster random write speeds. The 850 EVO delivers the top of its class performance in sequential read and write speeds. Plus, you also gain optimized random performance in all QD for client PC usage scenario.
Samsung's Magician software which provides rapid mode for 2x faster processing data speeds on a system level by utilizing unused PC memory (DRAM) as cache storage. The Magician increased the maximum memory usage in rapid mode. You also get a 2x performance boost in all random queue depth.
The 850 EVO delivers significantly longer battery life on your notebook with a controller optimized for 3D V-NAND now enabling device sleep at a highly efficiency. The 850 EVO is now 25% more power efficient during write operations thanks to 3D V-NAND only consuming half the energy than that of planar 2D NAND.
Optimize daily computing with TurboWrite technology for unrivaled read/write speeds
Achieve the ultimate read/write performance to maximize your everyday computing experience with Samsung's TurboWrite technology. You not only obtain more than a 10% better user experience but up to 1.9x faster random write speeds. The 850 EVO delivers the top of its class performance in sequential read and write speeds. Plus, you also gain optimized random performance in all QD for client PC usage scenario. -
Get into the fast lane with the improved rapid mode
Samsung's Magician software which provides rapid mode for 2x faster processing data speeds on a system level by utilizing unused PC memory (DRAM) as cache storage. The Magician increased the maximum memory usage in rapid mode. You also get a 2x performance boost in all random queue depth. -
Guaranteed endurance and reliability bolstered by 3D V-NAND technology
The 850 EVO delivers guaranteed endurance and reliability. The 850 EVO through minimized performance degradation allows sustained performance improvements of up to 30% proving to be one of the most dependable storage devices. -
Compute longer with improved energy efficiency backed by 3D V-NAND
The 850 EVO delivers significantly longer battery life on your notebook with a controller optimized for 3D V-NAND now enabling device sleep at a highly efficiency. The 850 EVO is now 25% more power efficient during write operations thanks to 3D V-NAND only consuming half the energy than that of planar 2D NAND. -
Secure valuable data through advanced - AES 256 encryption
The 850 EVO comes fortified with the hardware-based full disk encryption engine. The AES 256 encryption-bit security technology secures data without any performance degradation and complies with TCG Opal 2.0. -
Protect against overheating with a highly responsive - Dynamic Thermal Guard
The 850 EVO's Dynamic Thermal Guard constantly monitors and maintains ideal temperatures for the drive to operate in optimal conditions for the integrity of your data. When temperatures rise above an optimal threshold, the Thermal Guard automatically throttles temperatures down protecting your data while maintaining responsiveness to ensure your computer is always safe from overheating. -
Acquire an integrated in-house solution consisting of top-quality components
Samsung is the only SSD brand to design and manufacture all its components in-house allowing complete optimized integration. The result-enhanced performance, lower power consumption with DRAM cache memory and improved energy-efficiency with the MEX/MGX controller.
- Samsung 850 EVO MZ-M5E500BW - solid state drive - 500 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 500 GB
- Hardware Encryption
- Form Factor
- mSATA
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 512 MB
- TRIM support, DevSleep mode, 3D V-NAND Technology, Auto Garbage Collection Algorithm, Worldwide Name (WWN), Samsung MEX Controller, S.M.A.R.T., 256-bit AES, IEEE 1667
- 30 mm x 50.8 mm x 3.81 mm
- 9.07 g
- 5-year warranty
- Capacity
- 500 GB
- Form Factor
- mSATA
- Interface
- SATA 6Gb/s
- Buffer Size
- 512 MB
- 30 mm
- 50.8 mm
- 3.81 mm
- 9.07 g
Performance
- SSD Endurance
- 150 TB
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 540 MBps (read) / 520 MBps (write)
- Maximum 4KB Random Write
- 88000 IOPS
Reliability
- MTBF
- 1,500,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 52 pin mini-SATA
- Compatible Bay
- mSATA
- Power Consumption
- 50 mW (active) , 3.3 Watt (average) , 4.8 Watt (maximum)
- Software Included
- Samsung Magician Software
- Limited warranty - 5 years
- 0 °C
- 70 °C
- Shock Tolerance (non-operating)
- 1500 g @ 0.5 ms half-sine pulse
