Product
Samsung 500GB 860 EVO Series mSATA 6GB/s 2.5" SSD
Quicklinx: DBC6WS00 Mfr#: MZ-M6E500BW
Form Factor: mSATA
Capacity: 500GB, 500GB
Interface: Serial ATA-600
Type: Internal hard drive
Stock Status: Clearance
Hurry, only 1 left in stock!
£96.40 ex VAT
£115.68 inc VAT
Express delivery Order within the next 12 hours for delivery on Monday
THE SAMSUNG SSD 860 EVO
The Samsung SSD 860 EVO is the newest of Samsung’s Client-PC SATA SSDs, specially designed for mainstream desktops and laptops. Building on the reputation of the Samsung SSD 850 EVO, the world’s first line of consumer SSDs with V-NAND 3bit MLC technology, the new Samsung SSD 860 EVO drives achieve industry-leading performance for SATA SSDs, offering improvements in speed, reliability, compatibility and capacity. The 860 EVO comes equipped with Samsung’s newly designed MJX controller along with the latest V-NAND architecture.
Enhanced Computing Experiences
The Samsung SSD 860 EVO is the newest of Samsung’s Client-PC SATA SSDs, specially designed for mainstream desktops and laptops. Building on the reputation of the Samsung SSD 850 EVO, the world’s first line of consumer SSDs with V-NAND 3bit MLC technology, the new Samsung SSD 860 EVO drives achieve industry-leading performance for SATA SSDs, offering improvements in speed, reliability, compatibility and capacity. The 860 EVO comes equipped with Samsung’s newly designed MJX controller along with the latest V-NAND architecture. Enhanced Computing Experiences The legacy Serial-ATA (SATA) interface faces the theoretical bandwidth limitation of 600MB/s which many SSD manufacturers have tried to reach over the years. Among them, Samsung, which first brought V-NAND technology to the market, continuously strives to improve product reliability and performance, even with the SATA interface limitations. Powered by Samsung’s latest V-NAND technology, the 860 EVO delivers top-notch sequential read (up to 550 MB/s) and write (up to 520 MB/s) speeds and along with high sustainable performance for everyday computing experiences. As the amount of data processing continuously increases, the need for faster data transfers and sustainable high performance over longer periods of time has become paramount in importance for users. To address this need, Samsung has newly introduced Intelligent TurboWrite technology. With this, the 860 EVO provides significantly accelerated write performance which is up to 6 times longer than that of the previous 850 EVO. Intelligent TurboWrite automatically decides how much space to allocate to the TurboWrite region in accordance with your system workload. So in a heavy workload situation, TurboWrite region will expand by up to 6 times versus that of the previous version of TurboWrite. helping to avoid sudden write performance drops which sometimes occur when performing large file transfer and ensuring that consumers enjoy the best write performance for longer than ever.
Worry-Free Reliability
The 860 EVO offers guaranteed endurance and unmatched reliability, with up to 6 times higher Total Bytes Written (TBW) than the previous 850 EVO and an industry-leading 5 year limited warranty. Up to 2,400 TBW powered by the latest V-NAND technology will give you absolute confidence in your SSD.(1)
Furthermore, the 860 EVO assures long-term dependable performance with minimal performance degradation. The 860 EVO provides up to 51% better sustained performance compare to that of its predecessor. This means you can fully experience the performance of the SSD even with heavy daily workload.
Expanded Compatibility with a Refined Controllee
The 860 EVO delivers expanded system compatibility. The refined ECC algorithm and revamped controller generate strong sustainable performance near SATA’s limits, and the improved queued trim provides for better Linux compatibility. Also the 860 EVO is available in 2.5-inch, mSATA, and M.2 form factors for a broad range of computing device.
Advanced Data Encryption
The 860 EVO provides multiple advanced data encryption features. Self-Encrypting Drive (SED) security technology will help keep data safe at all times. The 860 EVO includes an AES 256-bit hardware-based encryption engine to ensure that your personal files remain secure. Being hardware-based, the encryption engine secures your data without the performance degradation that you may experience with software-based encryption. Also, the 860 EVO is compliant with various advanced security management solutions (TCG Opal and Encrypted Drive-IEEE1667).
Samsung Data Migration and Magician Software
The 860 EVO comes with Samsung Data Migration and Magician Software, which is easy to install and makes management of you SSD simple. (2) Samsung Data Migration software is uncomplicated to use – yet provides a very powerful "Custom Cloning" feature that makes migration effortless even when the source data is greater than the SSD’s capacity. Magician provides personalized firmware checks and additional functions tailored for individual users’ drives. It even updates the firmware automatically to make sure that the drives’ performance stays up to date.
(1) All documented endurance test results are obtained in compliance with JESD218 standards. Please visit www.jedec.org for detailed standard information.
(2) To download Samsung Data Migration and Magician, please visit www.samsung.com/samsungssd
Samsung 860 EVO MZ-M6E500BW - solid state drive - 500 GB - SATA 6Gb/s
Solid state drive - internal
500 GB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
3D multi-level cell (MLC)
mSATA
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
512 MB
TRIM support, Auto Garbage Collection Algorithm, TurboWrite Technology, eDrive, Samsung MJX Controller, 3-bit 3D V-NAND Technology, Low Power DDR4 SDRAM Cache, S.M.A.R.T., 256-bit AES, IEEE 1667
29.85 mm x 50.8 mm x 3.85 mm
8.5 g
5 years warranty
500 GB
Hardware Encryption
256-bit AES
mSATA
SATA 6Gb/s
Buffer Size
512 MB
29.85 mm
50.8 mm
3.85 mm
8.5 g
Performance
SSD Endurance
300 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
550 MBps (read) / 520 MBps (write)
Maximum 4KB Random Write
88000 IOPS
Maximum 4KB Random Read
97000 IOPS
Reliability
MTBF
1,500,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
mSATA
Power Consumption
2.5 Watt (average) , 4.5 Watt (maximum)
Limited warranty - 5 years
70 °C
Shock Tolerance (operating)
1500 g @ 0.5 ms half-sine
Form Factor: mSATA
Capacity: 500GB
Capacity: 500GB
Brand: Samsung
Price Range Ex VAT: 50 - 100
