Samsung 500GB 750 EVO Series 2.5" SATA 6Gb/s SSD
Quicklinx: C590WS00 Mfr#: MZ-750500BW
The Samsung 750 EVO boasts a fast random read/write (R/W) performance of up to 97K/88K Input/Output Operations Per Second (IOPS). With TurboWrite, write speeds for the 750 EVO are significantly accelerated during data transfers by creating a high-performance write buffer in the SSD. If a consecutive write operation (i.e. no idle time) exceeds the size of the buffer, the transfer will exit TurboWrite and be processed at "After TurboWrite" speeds. Once the buffer is cleared, TurboWrite performance will resume. However, the buffer size for TurboWrite is more than sufficient for everyday PC use, and you should experience accelerated speeds for most workloads.
With no moving parts, the NAND flashbased 750 EVO provides superb durability and is lightweight, making it the ideal choice for working on the go. It is also shock and vibration resistant for worryfree operation.
Data security is of the utmost importance for businesses and personal PC use as well. The 750 EVO ensures it remains safe with Samsung SED technology. It includes an AES 256-bit hardware-based encryption engine to ensure that your personal files remain secure. Being hardware-based, the encryption engine secures your data without performance degradation that you may experience with a software-based encryption.
  • Boost productivity with ultrafast computing speeds
  • Work worry-free anywhere with solid reliability
  • Secure priceless data with advanced data encryption
Samsung 750 EVO MZ-750500 - solid state drive - 500 GB - SATA 6Gb/s
Solid state drive - internal
500 GB
Hardware Encryption
Encryption Algorithm
256-bit AES
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
512 MB
Hardware Full Disk Encryption (FDE), TRIM support, sleep mode, DDR3 DRAM Cache, Auto Garbage Collection Algorithm, Worldwide Name (WWN), RAPID mode support, TurboWrite Technology, Samsung MGX Controller, S.M.A.R.T., IEEE 1667
69.85 mm x 100 mm x 6.8 mm
50 g
3-year warranty
500 GB
Hardware Encryption
256-bit AES
2.5"
SATA 6Gb/s
Buffer Size
512 MB
69.85 mm
100 mm
6.8 mm
50 g
Performance
SSD Endurance
100 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
540 MBps (read) / 520 MBps (write)
Maximum 4KB Random Write
88000 IOPS
Maximum 4KB Random Read
98000 IOPS
Reliability
MTBF
1,500,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Power Consumption
2.3 Watt (read) , 2.5 Watt (write) , 50 mW (idle) , 5 mW (sleep)
Software Included
Samsung Magician Software
Limited warranty - 3 years
70 °C
Shock Tolerance (non-operating)
1500 g @ 0.5 ms
