Speed it up
Speed it all up. Incredible speeds give the experience of a fast computer with fast boot-ups, shutdowns, transfers, and application responsiveness. -
Trusted reliability
Always be sure. The 860 QVO is your reliable alternative to legacy storage, built with Samsung V-NAND technology.
- Samsung 860 QVO MZ-76Q4T0BW - SSD - 4 TB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 4 TB
- Hardware Encryption
- Encryption Algorithm
- 256-bit AES
- NAND Flash Memory Type
- Multi-level cell (MLC)
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 4 GB
- TRIM support, Garbage Collection technology, sleep mode, V-NAND Technology, Samsung MJX Controller, Low Power DDR4 SDRAM Cache, S.M.A.R.T., 256-bit AES
- 69.85 mm x 100 mm x 6.8 mm
- 62 g
- 3-year warranty
- Capacity
- 4 TB
- 256-bit AES
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 4 GB
- 69.85 mm
- 100 mm
- 6.8 mm
- 62 g
Performance
- SSD Endurance
- 1440 TB
- Internal Data Rate
- 550 MBps (read) / 520 MBps (write)
- 4KB Random Read
- 7500 IOPS
- 4KB Random Write
- 42000 IOPS
- Maximum 4KB Random Write
- 89000 IOPS
- Maximum 4KB Random Read
- 97000 IOPS
Reliability
- MTBF
- 1,500,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 2.5"
- Power Consumption
- 3.1 Watt (average) , 5.4 Watt (maximum) , 0.03 Watt (idle)
- IEEE 1667
- Limited warranty - 3 years
- 0 °C
- 70 °C
- Shock Tolerance (operating)
- 1500 g @ 0.5 ms half-sine
