Samsung 4TB 860 QVO V-NAND 2.5" SATA 6Gb/s SSD
Quicklinx: DZ2VWS00 Mfr#: MZ-76Q4T0BW
Form Factor: 2.5"
Capacity: 4TB
Interface: Serial ATA-600
Type: Internal hard drive
22 in stock
£332.07 ex VAT
£398.48 inc VAT
Marketing description is not available.
  • Speed it up
    Speed it all up. Incredible speeds give the experience of a fast computer with fast boot-ups, shutdowns, transfers, and application responsiveness.
  • Trusted reliability
    Always be sure. The 860 QVO is your reliable alternative to legacy storage, built with Samsung V-NAND technology.
Samsung 860 QVO MZ-76Q4T0BW - solid state drive - 4 TB - SATA 6Gb/s
Solid state drive - internal - TRIM support, Garbage Collection technology, sleep mode, V-NAND Technology, Samsung MJX Controller, Low Power DDR4 SDRAM Cache
4 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
Multi-level cell (MLC)
2.5"
SATA 6Gb/s
Buffer Size
4 GB
TRIM support, Garbage Collection technology, sleep mode, V-NAND Technology, Samsung MJX Controller, Low Power DDR4 SDRAM Cache, S.M.A.R.T., 256-bit AES
10 cm x 6.985 cm x 0.68 cm
62 g
3-year warranty
4 TB
Hardware Encryption
256-bit AES
2.5"
SATA 6Gb/s
Buffer Size
4 GB
10 cm
6.985 cm
0.68 cm
62 g
Performance
SSD Endurance
1440 TB
Internal Data Rate
550 MBps (read) / 520 MBps (write)
4KB Random Read
7500 IOPS
4KB Random Write
42000 IOPS
Maximum 4KB Random Write
89000 IOPS
Maximum 4KB Random Read
97000 IOPS
Reliability
MTBF
1,500,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
2.5"
Power Consumption
3.1 Watt (average) , 5.4 Watt (maximum) , 0.03 Watt (idle)
IEEE 1667
Limited warranty - 3 years
70 °C
Shock Tolerance (operating)
1500 g @ 0.5 ms half-sine
Form Factor: 2.5"
Capacity: 4TB
Brand: Samsung
Price Range Ex VAT: 300 - 500
