Designed for gamers, IT admins and creative professionals, the Samsung 860 PRO is powered by V-NAND technology and a robust algorithm-based Samsung controller to handle the heavy workloads of high-end client PCs, workstations and NAS. Get fast, enduring performance with exceptional reliability and expanded compatibility.
- Samsung 860 PRO MZ-76P4T0B - SSD - 4 TB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 4 TB
- Hardware Encryption
- Encryption Algorithm
- 256-bit AES
- NAND Flash Memory Type
- 3D multi-level cell (MLC)
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 4 GB
- TRIM support, sleep mode, 3D V-NAND Technology, Auto Garbage Collection Algorithm, eDrive, Samsung MJX Controller, Low Power DDR4 SDRAM Cache, S.M.A.R.T., 256-bit AES, IEEE 1667
- 69.85 mm x 100 mm x 6.8 mm
- 62 g
- 5-year warranty
- Capacity
- 4 TB
- 256-bit AES
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 4 GB
- 69.85 mm
- 100 mm
- 6.8 mm
- 62 g
Performance
- SSD Endurance
- 4800 TB
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 560 MBps (read) / 530 MBps (write)
- 4KB Random Read
- 11000 IOPS
- 4KB Random Write
- 43000 IOPS
- Maximum 4KB Random Write
- 90000 IOPS
- Maximum 4KB Random Read
- 100000 IOPS
Reliability
- MTBF
- 2,000,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 2.5"
- Power Consumption
- 2.2 Watt (average) , 4.5 Watt (maximum)
- Software Included
- Samsung Magician Software
- WWN, IEEE 1667
- Limited warranty - 5 years
- 0 °C
- 70 °C
- Shock Tolerance (operating)
- 1500 g @ 0.5 ms half-sine
