Your basket is empty
Samsung 49" Full HD Ready Flat TV
Quicklinx: C1XRWS00 Mfr#: UE49K5100AKXXU
  • 1080p (Full HD)
Marketing description is not available.
Samsung UE49K5100AK 5 Series - 49" LED TV
LED-backlit LCD TV
Diagonal Class
49"
Indigo black
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Motion Enhancement Technology
200 Picture Quality Index, 50 Motion Rate
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
Wi-Fi (optional)
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
Digital TV Tuner
DVB-C, DVB-T2
Multi-channel Preview
Picture-in-picture (PIP)
Speaker System
2 speakers
USB
Remote Control
Standard remote
Voltage
AC 230V (50/60 Hz)
Energy Class
Class A
105 Watt
Power Consumption (On mode)
73 W
Energy Consumption per Year
107 kWh
109.68 cm x 8.8 cm x 67.62 cm
12.6 kg
LED-backlit LCD TV
Energy Class
Class A
105 Watt
73 W
107 kWh
Diagonal Class
49"
Series
5 Series
Sensors
Eco Sensor
Video Interface
HDMI Ports Qty
2 ports
Modes
Game mode, Film Mode
Design
Very Narrow Bezel Design (VNB), Slim Edge Mold Design
Dimensions
Without stand
109.68 cm
8.8 cm
67.62 cm
12.6 kg
Enclosure Colour
Indigo black
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
HyperReal Engine, Wide Color Enhancer Plus, USB Cloning, Digital Clean View, E-Manual, Mega Dynamic Contrast Ratio, Embeded POP
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
DVB-C, DVB-T2
Video Features
Electronic Programme Guide
Digital EPG
Media Player
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Remote Control Model
Samsung TM1240A
Audio System
Digital Audio Format
DTS digital output, Dolby Digital Plus output
Speaker System
2 speakers
Output Power / Total
20 Watt
Wallmount Sound Mode
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
Wi-Fi (optional)
Connect & Share
ConnectShare
Connector Type
2 x HDMI , USB 2.0 , Digital audio output (optical) , Composite video / component video input , Audio line-in
Batteries
Power supply
Nominal Voltage
AC 230V (50/60 Hz)
Power Consumption Stand by
0.3 Watt
Auto On/Off
Dimensions & Weight Details
Panel without stand - 109.68 cm x 8.8 cm x 67.62 cm x 12.6 kg , Panel with stand - 109.68 cm x 22.45 cm x 74.28 cm x 12.7 kg
Width (Shipping)
118.5 cm
Depth (Shipping)
15.5 cm
Height (Shipping)
76.5 cm
Weight (Shipping)
16.3 kg
C1XR C2G 2m USB 2.0 A/B Cable - Black In Stock £3.02
C1XR C2G 5m USB 2.0 A/B Cable - Black In Stock £4.42
C1XR C2G 2-Port USB 2.0 Manual Switch In Stock £16.36
C1XR C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £11.41
C1XR C2G 4-Port USB 2.0 Aluminum Hub In Stock £25.45
C1XR C2G 12m USB 2.0 A/A Active Extension Cable In Stock £14.97
C1XR C2G USB 2.0 To Fast Ethernet Adapter In Stock £19.05
