Samsung 49" Black LED Large Format Display Full HD
Quicklinx: D41FWS00 Mfr#: LH49DCHPLGC/EN
  • 1080p
With the Samsung DC49H, every business can now get the engagement and flexibility that digital signage offers. Featuring the sharp clarity and readability that Samsung is known for, your messages will be bright and engaging. Built to commercial quality standards, the Samsung DC49H is a superior, affordable alternative to TVs designed for the home. It's designed for long hours of continuous, reliable operation.
  • Slim, sleek design
    The DC49H features a slim 9.0mm (Top/Side)/11.0mm (Bottom) bezel width, an ADA-compliant profile of just 1.9" chassis depth and weighs only 28.8 lbs. So it's easy to install and showcases your message in an elegant way.
  • Exceptional image quality
    Achieve sharp, detail-rich images and crisp, legible type with this slim edge-lit LED display featuring 1920 x 1080 Full HD resolution with 350 nits of brightness and a 5000:1 contrast ratio.
  • Reliable 16/7 operation
    Samsung commercial displays are designed from the chassis up to deliver outstanding image quality with exceptional reliability. With the DC49H, you can count on 16/7 run times.
  • Versatile connectivity options
    Interfaces include HDMI, DVI-I, Component and Composite input as well as RS-232C and RJ45 for extensive connectivity. You can also attach a Set Back Box media player to transform your display into all-inclusive digital signage.
Samsung DC49H DCH Series - 49" LED-backlit LCD display - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
49"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Frame Rate & Enhancement Technology
60 Hz Refresh Rate
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15)
LCD Backlight Technology
Edge-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Picture Enhancements
Mega Dynamic Contrast Ratio
USB
Remote control
Voltage
Energy Class
Class A+
99 Watt
Power Consumption (On mode)
52 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
76 kWh
109.69 cm x 3.05 cm x 62.91 cm
13.1 kg
Energy Class
Class A+
99 Watt
52 W
76 kWh
Diagonal Class
49"
Commercial Use
Series
DCH Series
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15)
Dimensions
Without stand
109.69 cm
3.05 cm
62.91 cm
13.1 kg
Display
Resolution
1920 x 1080
Image Aspect Ratio
16:9
60 Hz Refresh Rate
Edge-lit LED
Image Contrast Ratio
5000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Media Player
USB Port
USB Ports Qty
1
Remote Control
Remote control
Connector Type
Audio line-in , 2 x HDMI , DVI-I input , Component video input , Composite video input , Audio line-out , LAN , USB , Serial input
Plug and Play, CSA, UL, TUV, C-Tick, BSMI, GOST, cUL, DDC-2B, NEMKO, NOM, SASO, CB, AS/NZS 60950-1, CCC, EMC, PSB, EK, IRAM, EN 60950-1, KCC, FCC Part 15 B Class A, KC, GB 9254-2008, NOM-019-SCFI-1998, KN22, KN24, K60950-1, cUL No.60950-1, EAC, RCM, IS13252, VCCI V-3/2010.04 Class A, CNS 14972, GOST-R 51317 series, GOST 22505-97, IEC609050-1, CNS 13438 Class A ITE EMI, CNS 13439 AV EMI, CNS 14409 AV EMS, GB 17625.1-2012, NOM-001-SCFI-1993, BIS, INMETRO, IEC60950-1, GB 4943.1-2011, AS/NZS CISPR 22:2009, EN 55024:1998+A1:2001+A2:2003, EN 55022:2006+A1:2007
Power supply
Input Voltage
0.5 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0 Watt
Width (Shipping)
121.4 cm
Depth (Shipping)
15.7 cm
Height (Shipping)
72.1 cm
Weight (Shipping)
17.4 kg
10 - 80% (non-condensing)
