Samsung PMH series premium displays achieve peak performance all while maintaining a stylish and captivating design. The PMH series displays leverage elevated brightness and refined image sharpness to ensure a consistently clear presentation even in settings with variable lighting.
Put your worries to rest knowing that your display is protected from a range of environmental conditions
PMH standalone displays feature a dust-resistant design and ability to withstand a range of environmental conditions. Customers can conveniently use this display without needing to prepare additional enclosure in dusty places. Uninterrupted, 24/7 content delivery is always assured regardless of surrounding natural or interactive conditions. -
Powerful performance and simple usability
The display supports 3 movies playing concurrently on one screen with enhanced 3D graphic performance. A holistic security architecture allows for powerful security through 3 layers of supplementation. -
Convenient display control through a centralized receiver
The standalone integrated centralized infrared receiver ensures easier and more flexible user control. All models can receive the IR signal on individual panels via central IR. -
Brilliant visual quality
The PMH series displays reduce natural and ambient light interference to ensure continuous readability in any location. Image visibility and information readability are deemed to be very high, because it is less reflective under light or sunlight, which poses no issues when used with QSR menu boards, or airport flight schedule boards with ample natural light.
- Samsung PM49H PMH Series - 49" LED display
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 49"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Display Format
- 1080p (Full HD)
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- Wi-Fi
- PC Interface
- DVI, DisplayPort
- LCD Backlight Technology
- LED backlight - edge-lit
- Image Aspect Ratio
- 16:9
- Picture Enhancements
- Mega Dynamic Contrast Ratio
- USB
- 2 ports
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class B
- 165 Watt
- Power Consumption (On mode)
- 98 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 136 kWh
- Dimensions (WxDxH) - without stand
- 109.69 cm x 3.05 cm x 62.91 cm
- 13.2 kg
- Product Type
- Energy Class
- Class B
- 165 Watt
- 98 W
- 136 kWh
- Diagonal Class
- 49"
- Commercial Use
- Series
- PMH Series
- TV Tuner Presence
- No
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- DVI, DisplayPort
- Dimensions
- Without stand
- 109.69 cm
- 3.05 cm
- 62.91 cm
- 13.2 kg
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p (Full HD)
- 16:9
- Coating
- 25% Glass Haze
- Image Contrast Ratio
- 4000:1
- Brightness
- 500 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 8 ms
- MagicInfo
Stands & Mounts
- Stand
- Optional
- VESA Mounting Interface
- 400 x 400 mm
Media Player
- USB Port
- USB Ports Qty
- 2
Network & Internet Multimedia
- Connectivity
- Wi-Fi
- Connector Type
- 2 x HDMI , DisplayPort input , DVI-Digital , 2 x USB , Audio line-in , Audio line-out , Serial input , Serial output , Multiple Display Control
- EMC Class A
- Power Device
- Power supply
- Nominal Voltage
- 0.5 Watt
- 0 Watt
- Width (Shipping)
- 121.4 cm
- Depth (Shipping)
- 15.7 cm
- Height (Shipping)
- 72.1 cm
- Weight (Shipping)
- 16.7 kg
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
