Samsung 49" Black, LED Large Format Display, Full HD, 500 cd/m2, 24/
Quicklinx: D4NTWS00 Mfr#: LH49PMHPBGC/EN
TV Tuner Presence: No
Video Interface: HDMI
  • 1080p (Full HD)
£831.98 ex VAT
£998.37 inc VAT
Samsung PMH series premium displays achieve peak performance all while maintaining a stylish and captivating design. The PMH series displays leverage elevated brightness and refined image sharpness to ensure a consistently clear presentation even in settings with variable lighting.
  • Put your worries to rest knowing that your display is protected from a range of environmental conditions
    PMH standalone displays feature a dust-resistant design and ability to withstand a range of environmental conditions. Customers can conveniently use this display without needing to prepare additional enclosure in dusty places. Uninterrupted, 24/7 content delivery is always assured regardless of surrounding natural or interactive conditions.
  • Powerful performance and simple usability
    The display supports 3 movies playing concurrently on one screen with enhanced 3D graphic performance. A holistic security architecture allows for powerful security through 3 layers of supplementation.
  • Convenient display control through a centralized receiver
    The standalone integrated centralized infrared receiver ensures easier and more flexible user control. All models can receive the IR signal on individual panels via central IR.
  • Brilliant visual quality
    The PMH series displays reduce natural and ambient light interference to ensure continuous readability in any location. Image visibility and information readability are deemed to be very high, because it is less reflective under light or sunlight, which poses no issues when used with QSR menu boards, or airport flight schedule boards with ample natural light.
Samsung PM49H PMH Series - 49" LED display - Full HD
LED-backlit LCD flat panel display
Diagonal Class
49"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
HDMI
HDMI Ports Qty
2 ports
Wi-Fi
PC Interface
DVI, DisplayPort
LCD Backlight Technology
LED backlight - edge-lit
Image Aspect Ratio
16:9
Picture Enhancements
Mega Dynamic Contrast Ratio
USB
2 ports
Voltage
Energy Class
Class B
165 Watt
Power Consumption (On mode)
98 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
136 kWh
109.69 cm x 3.05 cm x 62.91 cm
13.2 kg
Energy Class
Class B
165 Watt
98 W
136 kWh
Diagonal Class
49"
Commercial Use
Series
PMH Series
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, DisplayPort
Dimensions
Without stand
109.69 cm
3.05 cm
62.91 cm
13.2 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Coating
25% Glass Haze
Image Contrast Ratio
4000:1
Brightness
500 cd/m²
Viewing Angle
178°
Viewing Angle (Vertical)
178°
Response Time
8 ms
MagicInfo
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Media Player
USB Port
USB Ports Qty
2
Network & Internet Multimedia
Wi-Fi
Connector Type
2 x HDMI , DisplayPort input , DVI-Digital , 2 x USB , Audio line-in , Audio line-out , Serial input , Serial output , Multiple Display Control
EMC Class A
Power supply
Nominal Voltage
0.5 Watt
Power Consumption (Off Mode)
0 Watt
Width (Shipping)
121.4 cm
Depth (Shipping)
15.7 cm
Height (Shipping)
72.1 cm
Weight (Shipping)
16.7 kg
10 - 80% (non-condensing)
Brand: Samsung
Price Range Ex VAT: £750 - £1000
