Samsung 480GB 983 ZET SATA PCIe 2.5" SSD
Quicklinx: F8JTWS00 Mfr#: MZ-PZA480BW
Bridging the gap between enterprise storage and cache memory with ultra-low latency. The 983 ZET bridges the gap between storage memory and cache memory by offering a new level of performance with ultra-low latency, high QoS, breakthrough speeds and ultra-high reliability. Ideal for high-performance computing applications such as hybrid caching servers, database servers, AI and IoT, the 983 ZET is a perfect companion to Samsung's DCT SSDs as a powerful cache memory solution to completely enhance server performance.
Samsung 983 ZET MZ-PZA480BW - SSD - 480 GB - PCIe 3.0 x4 (NVMe)
Solid state drive - internal (desktop)
480 GB
Hardware Encryption
PCIe card (HHHL)
PCIe 3.0 x4 (NVMe)
Buffer Size
1.5 GB
TRIM support, Auto Garbage Collection Algorithm, V-NAND Technology, Low Power DDR4 SDRAM Cache, Samsung Phoenix Controller, S.M.A.R.T.
69.9 mm x 167.7 mm x 18.8 mm
330 g
5-year warranty
480 GB
Hardware Encryption
PCIe card (HHHL)
PCIe 3.0 x4 (NVMe)
Buffer Size
1.5 GB
69.9 mm
167.7 mm
18.8 mm
330 g
Performance
SSD Endurance
7.44 PB
Internal Data Rate
3400 MBps (read) / 3000 MBps (write)
Maximum 4KB Random Write
60000 IOPS
Maximum 4KB Random Read
750000 IOPS
Reliability
MTBF
2,000,000 hours
Expansion & Connectivity
1 x PCI Express 3.0 x4 (NVMe) - PCI Express
Compatible Bay
PCIe card (HHHL)
Power Consumption
9 Watt (typical) , 5.5 Watt (idle)
Software Included
Samsung SSD Magician DC
Limited warranty - 5 years
55 °C
Shock Tolerance (operating)
1500 g @ 0.5 ms half-sine
