Samsung 40" Freeview FHD Commercial TV
Quicklinx: D8C6WS00 Mfr#: HG40EE670DKXXU
  • 1080p
Successful hoteliers understand that today's hospitality consumers are media- and tech-savvy guests that expect sophisticated in-room entertainment and an overall stay experience beyond what they are accustomed to at home. Samsung's HE670 hospitality display boasts coaxial-based infrastructure to efficiently manage diversified content and deliver through a modern, streamlined design that enhances content viewing. A swivel stand completes its sleek appearance and adds the functionality of viewing from various angles of the room. Multi-functional programming settings are quickly available with a home menu, so guests can easily navigate to stay informed and entertained.
  • Enjoy more efficient installation through improved Plug-and-Play capabilities
    In a busy hospitality environment, time spent on display installation and maintenance is time that could otherwise be devoted to more critical growth-related activities. Through advanced Plug-and-Play settings, hotel managers can activate hundreds of in-room displays with minimal effort required.
  • System Integrator (SI) compatibility
    Save time and effort when setting up multiple protocols between SI-provided set-top boxes and displays. Samsung SMART Hospitality Displays are compatible with various SI protocols.
  • Security Mode
    Gain unique and strong display content management with Security Mode on HD470 Series displays. Using this feature, you can disable critical functions of the displays to easily prevent changes to the displays' settings. You can also block non-compliant content or the transmission of unwanted Teletext (TTX) with a signal to maintain complete control of content on guest room displays, including input through HDMI and USB ports.
  • Multi-code remote
    Increase guests' TV-viewing enjoyment by eliminating annoying interference from other remote signals in applications, such as hotel fitness centers, where multiple TVs are in close proximity. The multi-code remote can control up to 10 TVs individually in the same room.
  • My Channel
    Enable guests to easily find and enjoy the programming of their choice without having to manually scroll through hundreds of TV channels. My Channel's quick search function allows guests to find channels suited to their tastes, by country and genre.
  • Connect share
    Media entertainment including movies, music, and images come alive on the screen by simply plugging a USB drive directly into the TV.
  • Sports Mode
    Sports fans don't have to miss their favorite games when staying at your hotel. They can watch every goal or point scored with superior-quality picture and sound, right in their rooms. With Sports Mode, guests can use a shortcut to activate enhanced sound and picture quality.
Samsung HG40EE670DK HE670 Series - 40" LED-backlit LCD display - Full HD - for hotel / hospitality
LED-backlit LCD flat panel display
Diagonal Class
40"
Commercial Use
Yes - hotel / hospitality
Dark titan
Resolution
1920 x 1080
Display Format
1080p
Video Interface
Composite, HDMI
HDMI Ports Qty
2 ports
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
1x analogue, 1x digital
Digital TV Tuner
DVB-C, DVB-T2
Multi-channel Preview
Picture-in-picture (PIP)
Commercial Features
Music Mode, screen welcome message, My Channel, Soundbar, Smoovie, mixed channel list, Software Clock, Hotel Channel List, Multi remote control, Samsung LYNK REACH, Auto Source Mode, Samsung LYNK DRM, Energy Saving Mode (BLU control), Hospitality Home Menu, Security Mode, Hospitality Plug & Play (Easy Set-up), Power On Mode, External Clock compatible, External Clock Dimming Control, Screwed Remote Battery Cover, Clock Back Up Supply, Hospital Logo Display with Time Out Setting, Samsung LYNK REACH RF Modulator Compatibility
Settings Cloning Capability
Speaker System
2 speakers
USB
Samsung TM1240A remote control, batteries, stand mount kit
Voltage
AC 230V (50/60 Hz)
Energy Class
Class A+
95 Watt
Power Consumption (On mode)
40 W
Power Consumption Stand by
0.4 Watt
Energy Consumption per Year
58 kWh
91.76 cm x 5.42 cm x 53.92 cm
8.5 kg
Energy Class
Class A+
95 Watt
40 W
58 kWh
Diagonal Class
40"
Commercial Use
Series
HE670 Series
TV Tuner
TV Tuner Presence
Video Interface
Composite, HDMI
HDMI Ports Qty
2 ports
Modes
Game mode, Film Mode, Sports mode
Dimensions
Without stand
91.76 cm
5.42 cm
53.92 cm
8.5 kg
Enclosure Colour
Dark titan
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Brightness
300 cd/m²
Display Menu Language
Multilingual
Commercial Features
HyperReal Engine, Wide Color Enhancer Plus, USB Cloning, RJP Compatible, Digital Clean View, Mega Contrast
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Stand Features
Swivel
Flat Panel Mount Interface
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
DVB-C, DVB-T2
HDTV Tuner
Digital TV Service
HbbTV
Video Features
Teletext
Electronic Programme Guide
Digital EPG
Media Player
USB Port
USB Ports Qty
1
Remote Control
Remote control
Remote Control Model
Samsung TM1240A
Multi-Code Remote
Audio System
Digital Audio Format
DTS digital output, Dolby Digital Plus output
Speaker System
2 speakers
Output Power / Total
20 Watt
Down-firing Speaker, Audio Return Channel (ARC), Bass Reflex System (BRS), Wallmount Sound Mode
Speakers
1 x left channel speaker - 10 Watt , 1 x right channel speaker - 10 Watt
Network & Internet Multimedia
Connect & Share
ConnectShare
Supported Consumer Electronics Control (CEC)
Anynet Plus
Connector Type
2 x HDMI , USB 2.0 , Composite video input , Headphones , Audio line-in , Remote control
Batteries, stand mount kit
Data cable
Power supply
Input Voltage
AC 230V (50/60 Hz)
0.4 Watt
Auto On/Off
On/off timer
Dimensions & Weight Details
Panel without stand - 91.76 cm x 5.42 cm x 53.92 cm x 8.5 kg , Panel with stand - 91.76 cm x 22.65 cm x 59.11 cm x 11.4 kg
Width (Shipping)
110.5 cm
Depth (Shipping)
11.6 cm
Height (Shipping)
63.6 cm
Weight (Shipping)
13.2 kg
