Your basket is empty
Samsung 4-CH 960H 4 Camera 700TVL CCTV Kit 500GB
Quicklinx: BBY9WS00 Mfr#: SDS-P3042/EU
For your home or business, Samsung SDS-P3042 is your security system that is both dependable and affordable. Everything you need to setup and get started is in the box. The SDS-P3042 features a 4 channel DVR with a 500 GB hard drive. In the box, you will find 4 IP66 night vision weather proof cameras. Simple to set up and even easier to use, you can monitor your business or home anytime from anywhere around the world so you will always know what is going on.
SAMSUNG TECHWIN SDS-P3042 - DVR + camera(s)
System
DVR + camera(s)
Security DVR
4 channels
Hard Drive
1 x 500 GB
Camera
4 cameras - PAL - night vision
31.5 cm x 22.4 cm x 5.2 cm
1.53 kg
System
DVR + camera(s)
Package Content
4 cameras, DVR, manual, remote control, mouse, power adapter
Camera cable - BNC - 4 pcs. , Network cable - 1 pcs. , HDMI cable - 1 pcs.
Software Included (Y)
Drivers & Utilities
Security DVR
Video Channels
4
Frame Rate (Playback)
100 fps (PAL)
Frame Rate (Record)
100 fps (PAL)
Image Resolution
704x576 (PAL), 352x288 (PAL), 704x288 (PAL), 960x576 (PAL)
Compression Format
G.711, H.264
Record Events
Timer, scheduled, event, manual
Watermark, picture-in-picture (PIP), e-mail alarm notifications, SmartViewer, Webviewer, Mobile Viewer
Hard Drive
Quantity Installed
1
500 GB
Serial ATA
Cameras
Quantity
4 cameras
Sensor
CMOS - 1/3" - 976x582
Horizontal Resolution (TV Lines)
700
Scanning System
Interlace
TV System
PAL
Night Vision
Signal-To-Noise Ratio
46 dB
White Balance
Auto
Gain Control
Auto
Focal Length
3.8 mm
Voltage
DC 12 V
Power Consumption
3 Watt
-10 °C
50 °C
Operating Humidity
20-85%
IP66
Video Input Ports
BNC x 4
Video Output Ports
HDMI x 1, VGA x 1
Audio Input Ports
RCA x 4
Audio Output Ports
RCA x 1
Network Port
10/100Base-T
Other Ports
USB 2.0 x 2, eSATA x 1, serial RS-485 x 1
31.5 cm
22.4 cm
5.2 cm
1.53 kg
Details
Camera: 7.21 cm x 19.24 cm x 6.29 cm - 252 g , DVR: 31.5 cm x 22.4 cm x 5.2 cm - 1.53 kg
