Your basket is empty
Samsung 4-CH 960H 2 Camera 700TVL CCTV Kit 500GB
Quicklinx: BBY8WS00 Mfr#: SDS-P3022/EU
Designed to maximize both your surveillance capabilities and your convenience, this All-In-One 4 channel, 2 camera DVR package is easily customized to provide advanced monitoring and notification options.
Complete with 2 cameras, the system is expandable to two more. Each weatherproof, 720 TVL resolution camera delivers true daylight color and clarity and clear night vision up to 82 ft. Samsung accommodates your specific needs with its Privacy Masking feature which allows blocking up to four areas within the camera's field of view. Concentrate only on points of interest and eliminate unnecessary motion detection alerts.
SAMSUNG TECHWIN SDS-P3022 - DVR + camera(s)
System
DVR + camera(s)
Security DVR
4 channels
Hard Drive
1 x 500 GB
Camera
2 cameras - outdoor - PAL - night vision
31.5 cm x 22.4 cm x 5.2 cm
1.53 kg
System
DVR + camera(s)
Package Content
2 cameras, DVR, manual, remote control, mouse, power adapter
Camera cable - BNC - 18.3 m - 2 pcs. , Network cable - 1 pcs. , HDMI cable - 1 pcs.
Software Included (Y)
Drivers & Utilities, Samsung Smart Viewer
Security DVR
Video Channels
4
Frame Rate (Record)
100 fps (PAL)
Image Resolution
720x576 (PAL), 704x576 (PAL), 352x288 (PAL), 704x288 (PAL), 960x576 (PAL)
Compression Format
G.711, H.264
Record Events
Motion detection, scheduled, event, manual, continuous, tamper detection, time lapse, video loss
Watermark, picture-in-picture (PIP), SmartViewer, Webviewer, smartphone support, Mobile Viewer, 960H Technology
Hard Drive
Quantity Installed
1
500 GB
Serial ATA
Cameras
Quantity
2 cameras
Camera Type
Outdoor
Sensor
CMOS - 1/3" - 976x494
Field Of View
60° (H), 48° (V)
Horizontal Resolution (TV Lines)
700
Scanning System
Interlace
TV System
PAL
Sensitivity (lux)
0
Night Vision
Infrared LEDs
Infrared Distance
25 m
Signal-To-Noise Ratio
46 dB
White Balance
Auto
Gain Control
Auto
Focal Length
3.8 mm
Voltage
DC 12 V
Power Consumption
3 Watt
-10 °C
50 °C
Operating Humidity
20-85%
IP66
Video Input Ports
BNC x 4
Video Output Ports
HDMI x 1, VGA x 1
Audio Input Ports
RCA x 4
Audio Output Ports
RCA x 1
Network Port
10/100Base-T
Other Ports
USB 2.0 x 2, eSATA x 1, serial RS-485 x 1
31.5 cm
22.4 cm
5.2 cm
1.53 kg
Details
DVR: 31.5 cm x 22.4 cm x 5.2 cm - 1.53 kg , Camera: 7.21 cm x 19.24 cm x 6.29 cm - 252 g
