Samsung 390F 31.5" 4ms HDMI Curved Monitor
Quicklinx: C3M6WS00 Mfr#: LC32F391FWUXEN
Select:
  • 31.5"
For gamers, getting immersed into the action is the whole point of the fun. So it is essential to have a monitor that can keep up with the intense demands of today’s games, without lagging or stuttering, and completely absorb players. Samsung’s curved monitors' curve with a radius of 1.8 meters helps to create a sense of surrounding the player, pulling them all the way into the action of the game.
In addition to that curvature technology, each of Samsung’s gaming monitors helps prevent eye strain and fatigue with embedded flicker-free and Eye Saver technologies.
Samsung C32F391FWU - CF391 Series - LED monitor - curved - Full HD (1080p) - 32"
LED-backlit LCD monitor - 32"
Energy Class
Class F
Energy Consumption per Year
45 kWh
Power Consumption (On mode)
31 W
Curved Screen
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
3000:1
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72% (NTSC 1976)
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Tilt
Voltage
AC 120/230 V
Brilliant white
72.43 cm x 24.77 cm x 52.22 cm
6.2 kg
Display Type
Energy Class
Class F
45 kWh
Diagonal Size
32"
Curved Screen
Yes (1800R)
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
3000:1
Colour Support
Colour Gamut
72% (NTSC 1976)
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
MagicBright, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Mercury free, Image Size, Eco Saving Plus, Eye Saver Mode
Brilliant white
72.43 cm x 24.77 cm x 52.22 cm - with stand
6.2 kg
DisplayPort , HDMI , Headphones
Mechanical
Tilt
Tilt Angle
-2/+22
VESA Mounting Interface
75 x 75 mm
Input Voltage
AC 120/230 V
31 W
31 kWh/1000h
Power Consumption (Typical)
35 Watt
Power Consumption (Off Mode)
0.3 Watt
Windows 10
Dimensions & Weight Details
With stand - width: 72.43 cm - depth: 24.77 cm - height: 52.22 cm - weight: 6.2 kg , Without stand - width: 72.43 cm - depth: 9.44 cm - height: 42.8 cm - weight: 5.4 kg
10 °C
10 - 80% (non-condensing)
