Samsung 390F 24" 4ms HDMI Curved Monitor
Quicklinx: C3M3WS00 Mfr#: LC24F390FHUXEN
Select:
  • 23.5"
The curvature of the screen provides a truly immersive viewing experience that lets you enjoy big, bold and stunning panoramic views while you work or play. With its design inspired by the curve of the human eye, the Samsung CF390 monitor delivers a comfortable and enjoyable viewing experience for your home or office use. It features an ultra-slim and sleek profile that makes a stylish statement while staying productive.
  • Immersive viewing experience with curved screen
    The 1800 R curvature of the screen provides a truly immersive viewing experience that lets you enjoy big, bold and stunning panoramic views while you work or play. With its design inspired by the curve of the human eye, the Samsung CF390 monitor delivers a comfortable and enjoyable viewing experience for your home or office use.
  • Ultra-slim design
    Featuring an ultra-slim and sleek profile the Samsung CF390 monitor makes a stylish statement while staying productive with the 23.5" curved screen. The simple circular stand will add a modern look to your space.
  • Advanced gaming experience with AMD FreeSync
    AMD FreeSync technology allows users to enjoy smooth images, even during the ultra-fast moving scenes. AMD FreeSync dynamically syncs the screen refresh rate with the frame rate of your content to minimize input latency and dramatically reduce image tearing and stutter during gaming. With its 4 ms response time, you'll see the ultra-fast on-screen motion clearly and smoothly with less motion blur, judder and ghosting. The fast response time provides a steady visual, allowing players to experience their games at a high level.
  • Eye Saver mode
    Eye Saver mode optimizes your viewing comfort by reducing blue light emissions and flickers at the touch of a button. Read documents, play games, watch movies and edit photos for long periods of time, and experience a comfortable and pleasing view, without worrying about eye strain or fatigue.
  • Brilliant picture quality
    Experience vibrant, stunningly vivid colors with Samsung's Active Crystal Color technology. The excellent 3000:1 contrast ratio delivers deep blacks and bright whites so you can clearly see even in an extremely dark or bright scene.
Samsung C24F390FHU - CF390 Series - LED monitor - curved - Full HD (1080p) - 23.5"
LED-backlit LCD monitor - 23.5"
Energy Class
Class G
Energy Consumption per Year
35 kWh
Power Consumption (On mode)
24 W
Curved Screen
Adaptive-Sync Technology
AMD FreeSync
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.271 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Shiny black
54.78 cm x 20.65 cm x 41.82 cm
3.3 kg
DDC-2B, ISO 9241-307
Display Type
Energy Class
Class G
35 kWh
Diagonal Size
23.5"
Curved Screen
Yes (1800R)
AMD FreeSync
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.271 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1
Colour Support
Response Time
4 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
MagicBright, power off timer, HDCP, game mode, Mega Dynamic Contrast Ratio, Eco Saving, Magic Upscale, Flicker Free technology, Mercury free, Eye Saver Mode
Shiny black
54.78 cm x 20.65 cm x 41.82 cm - with stand
3.3 kg
VGA , HDMI (HDCP) , Headphones
Mechanical
Tilt
1 x HDMI cable
24 W
24 kWh/1000h
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Apple MacOS, Windows 10
Dimensions & Weight Details
With stand - width: 54.78 cm - depth: 20.65 cm - height: 41.82 cm - weight: 3.3 kg , Without stand - width: 54.78 cm - depth: 8.76 cm - height: 32.63 cm
