Full HD resolution
Enjoy crisp and clear Full HD picture quality with vibrant images delivered through Wide Color Enhancer technology. Digital Clean View technology analyzes the quality of the signal input to improve your viewing experience and deliver brilliant picture quality. -
Ultra Clean View
Ultra Clean View analyzes the input signal and removes detected noise from the feed. No matter what quality the signal Ultra Clean View improves what you see. -
Enhanced contrast for sharper details
Micro Dimming technology divides the TV screen into hundreds of small zones, analyzing each one independently to adjust color, brightness and sharpness so you can experience better shadow detail and accurate color when watching your favorite video content. -
Deeper contrasts bring images to life
Experience the realistic TV viewing on a flat screen with the Contrast Enhancer. It adjusts contrast intelligently on different parts of the screen to heighten the dramatic effect. -
Enjoy enhanced colors and better images
Using an advanced picture quality improvement algorithm, Samsung's Wide Color Enhancer drastically improves the quality of any image, uncovering hidden details and allowing you to see colors as they were meant to be. -
Faster speeds, stronger performance
Experience a fast and fluid browsing experience with quad-core processor. Access a variety of different content sources, switch between apps, stream content, play online video games and multi-task seamlessly from the Smart Hub with ease. -
Dive into your video content
Motion Rate 60 offers immersive viewing with flicker-free video content. The amazing refresh rate and backlight technology will keep you at the edge of your seat with fast and seamless video. -
Simple and fast wireless connection
The built-in Wireless LAN lets you connect your Smart TV to the Internet without the tangle of cables. With the streamlined connections, now you can really enjoy your TV's outstanding design. -
Plug your entertainment into the TV
Using ConnectShare, you can watch a variety of content in one simple step. Just plug your USB or HDD into the TV and enjoy your movies, music, and pictures on the big screen.
- Samsung UE32K5500AK K5500 Series - 32" LED-backlit LCD TV - Full HD
- Product Type
- LED-backlit LCD TV - Smart TV
- Diagonal Class
- 32"
- Dark titan
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Frame Rate & Enhancement Technology
- 400 Picture Quality Index
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 3 ports
- Connectivity
- Wi-Fi, LAN
- LCD Backlight Technology
- LED backlight Micro Dimming Pro
- Image Aspect Ratio
- 16:9
- Digital TV Tuner
- DVB-C, DVB-T2
- Internet Streaming Services
- HbbTV
- Multi-channel Preview
- Picture-in-picture (PIP)
- USB
- 2 ports
- Included Accessories
- Remote control, batteries, Samsung TM1240A remote control
- Voltage
- AC 230V (50/60 Hz)
- Energy Class
- Class A
- 85 Watt
- Power Consumption (On mode)
- 40 W
- Power Consumption Stand by
- 0.3 Watt
- Energy Consumption per Year
- 55 kWh
- Dimensions (WxDxH) - without stand
- 73 cm x 5.5 cm x 44 cm
- 5.5 kg
- Product Type
- Energy Class
- Class A
- 85 Watt
- 40 W
- 55 kWh
- Diagonal Class
- 32"
- Series
- K5500 Series
- Video Processor
- Quad-Core
- TV Tuner Presence
- Extended PVR
- Video Interface
- HDMI Ports Qty
- 3 ports
- Modes
- Game mode, Natural Mode, Sports Mode Advanced, Cinema mode
- Design
- Very Narrow Bezel Design (VNB)
- Dimensions
- Without stand
- 73 cm
- 5.5 cm
- 44 cm
- 5.5 kg
- Enclosure Colour
- Dark titan
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- HyperReal Engine, Wide Color Enhancer Plus, USB Cloning, E-Manual, Instant On, Multiroom Compatible, Accessibility Zoom, Accessibility High contrast
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Flat Panel Mount Interface
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- DVB-C, DVB-T2
- HDTV Tuner
- Digital TV Service
- HbbTV
Video Features
- Teletext
- Electronic Programme Guide
- Digital EPG
Media Player
- USB Port
- USB Ports Qty
- 2
Remote Control
- Remote control
Audio System
- Digital Audio Format
- DTS digital output, Dolby Digital Plus output
- Output Power / Total
- 20 Watt
- Audio Return Channel (ARC)
- Speakers
- 2 x main channel speaker
Network & Internet Multimedia
- Functionality
- Digital audio playback, digital photo playback, digital video playback, Internet video playback
- Connectivity
- Wi-Fi, LAN
- LAN Protocol
- Ethernet
- Connect & Share
- Wi-Fi Direct, Screen Mirroring, ConnectShare, Sound Share
- HbbTV
- Supported Consumer Electronics Control (CEC)
- Anynet Plus
- DLNA
- Connector Type
- 3 x HDMI , 2 x USB 2.0 , LAN , Digital audio output (optical) , Composite video / component video input , Audio line-in
- Batteries, Samsung TM1240A remote control
- CEC
- Power Device
- Power supply
- Input Voltage
- 0.3 Watt
- Auto On/Off
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 73 cm x 5.5 cm x 44 cm x 5.5 kg , Panel with stand - 91.76 cm x 20.8 cm x 48.8 cm x 6.2 kg
- Width (Shipping)
- 89.4 cm
- Depth (Shipping)
- 11 cm
- Height (Shipping)
- 54 cm
- Weight (Shipping)
- 8.3 kg
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.20 |
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.06 |
