Your space. Your unique lifestyle. Joiiii
Enjoy crisp and clear 100 PQI HD content with vibrant images delivered through Wide Colour Enhancer technology. Digital Clean View technology analyses the quality of the signal input, improving your viewing experience and delivering superior picture quality.
HD Ready
Joiiii Design
The unique Joiiii design is sophisticated and elegant with adjustable legs, making it adaptable to fit anywhere in the home. You can also enjoy crisp and clear sound from the unique front firing speaker and tweeters. Your TV has never sounded so good.
Using an advanced picture quality improvement algorithm, Samsung's Wide Colour Enhancer drastically improves the quality of any image, uncovering hidden details and allowing you to see colours as they were meant to be seen.
Create your own entertainment space
Samsung TVs support HDMI inputs, which lets you create a multimedia entertainment centre in your own living room. Connect HDMI straight into your TV to view various contents from multiple devices.
What's In The Box?
- TV
- Manual/ Quick Guide
- Power Cable
- Remote Control
- Batteries (AAA x2)
HD ready
Enjoy crisp and clear 100 PQI HD content with vibrant images delivered through Wide Color Enhancer technology. Digital Clean View technology analyses the quality of the signal input, improving your viewing experience and delivering superior picture quality. -
Joiiii design
The unique Joiiii design is sophisticated and elegant with adjustable legs, making it adaptable to fit anywhere in the home. You can also enjoy crisp and clear sound from the unique front firing speaker and tweeters. Your TV has never sounded so good. -
Wide color enhancer
Using an advanced picture quality improvement algorithm, Samsung's Wide Color Enhancer drastically improves the quality of any image, uncovering hidden details and allowing you to see colors as they were meant to be seen. -
Samsung TVs support HDMI inputs, which lets you create a multimedia entertainment center in your own living room. Connect HDMI straight into your TV to view various contents from multiple devices.
- Samsung UE32K4100AK 4 Series - 32" LED-backlit LCD TV - HD
- Product Type
- LED-backlit LCD TV
- Diagonal Class
- 32"
- Indigo black
- Resolution
- 1366 x 768
- Display Format
- 720p
- Frame Rate & Enhancement Technology
- 100 Picture Quality Index, 50 Motion Rate
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- Wi-Fi (optional)
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- Digital TV Tuner
- DVB-C, DVB-T2
- Multi-channel Preview
- Picture-in-picture (PIP)
- Speaker System
- 2 speakers
- USB
- Included Accessories
- Samsung TM1240A remote control, batteries
- Voltage
- AC 230V (50/60 Hz)
- Energy Class
- Class A
- 48 Watt
- Power Consumption (On mode)
- 34 W
- Power Consumption Stand by
- 0.3 Watt
- Energy Consumption per Year
- 50 kWh
- Dimensions (WxDxH) - without stand
- 72.87 cm x 7.8 cm x 46.88 cm
- 4.7 kg
- Product Type
- Energy Class
- Class A
- 48 Watt
- 34 W
- 50 kWh
- Diagonal Class
- 32"
- Series
- 4 Series
- TV Tuner Presence
- Sensors
- Eco Sensor
- Video Interface
- HDMI Ports Qty
- 2 ports
- Modes
- Game mode, Film Mode
- Design
- Normal Narrow Bezel Design (NNB), Slim Edge Mold Design
- Dimensions
- Without stand
- 72.87 cm
- 7.8 cm
- 46.88 cm
- 4.7 kg
- Enclosure Colour
- Indigo black
Display
- Resolution
- 1366 x 768
- Display Format
- 720p
- 16:9
- LED backlight
- HyperReal Engine, Wide Color Enhancer Plus, USB Cloning, Digital Clean View, E-Manual, Mega Dynamic Contrast Ratio, Embeded POP
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Flat Panel Mount Interface
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- DVB-C, DVB-T2
- MPEG Profiles and Levels
- MHEG5
Video Features
- Electronic Programme Guide
- Digital EPG
Media Player
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
- Remote Control Model
- Samsung TM1240A
Audio System
- Digital Audio Format
- DTS digital output, Dolby Digital Plus output
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Wallmount Sound Mode
- Speakers
- 2 x main channel speaker - 10 Watt
- Driver Details
- Main channel speaker: 2 x full-range driver
Network & Internet Multimedia
- Connectivity
- Wi-Fi (optional)
- Connect & Share
- ConnectShare
- Connector Type
- 2 x HDMI , USB 2.0 , Digital audio output (optical) , Composite video / component video input , Audio line-in
- Batteries
- Power Device
- Power supply
- Input Voltage
- 0.3 Watt
- Auto On/Off
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 72.87 cm x 7.8 cm x 46.88 cm x 4.7 kg , Panel with stand - 72.87 cm x 18.53 cm x 52.17 cm x 4.8 kg
- Width (Shipping)
- 79.1 cm
- Depth (Shipping)
- 13.2 cm
- Height (Shipping)
- 52.5 cm
- Weight (Shipping)
- 6.5 kg
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
