Samsung 32" Frame Art QLED Full HD HDR Smart TV
Quicklinx: GV08WS00 Mfr#: QE32LS03BBUXXU
  • 1080p
Make your own TV
The Frame 32" is the perfect finishing touch to elevating any room in your home. More than just a TV – it’s a glare-free canvas that can be endlessly transformed, inspiring you to reinvent your space. Each and every day.
Matte Display
Watching a midnight drama or a dramatic artwork? Luckily, The Frame’s ground-breaking, glare-free display absorbs reflections – so even in bright light, you’ll be watching the drama, not yourself.
Art Mode
Instead of fading to black when the TV is off, The Frame turns into a glare-free canvas to showcase a gallery of iconic art and stunning photography – including your own. Better still, with The Frame 32" you can switch to Vertical Mode and shake up the way you view your Art.
  • Matte screen
    Admire the artwork on your screen and feel its original texture. Thanks to the matte screen, enjoy your content without reflections.
  • Slimmer design
    The Frame's minimalist design blends perfectly with your décor. Connect the virtually invisible single cable and discover what makes The Frame a modern work of art, on or off.
  • Motion sensor
    When you're nearby, the motion sensor detects your presence and automatically turns on the screen. When you leave the room, it switches off to save energy.
  • 100% Color Volume
    Samsung's Quantum Dot technology delivers 100% color volume. It offers over a billion shades of color for even more realistic images. Combined with Dual LED technology, images have greater contrast and wider viewing angles.
  • Smart TV home pages
    Samsung's Smart home bar puts content selection and discovery at the forefront, so you spend less time searching and more time watching movies, shows and other content you enjoy.
  • Mobile Mirroring technology
    Take part in your conferences on the big screen. With SmartThing on your Android smartphone or AirPlay on iPhone, share your smartphone screen on The Frame for a better experience.
  • Object Tracking Sound Lite
    With OTS technology, sound moves dynamically as objects on the screen move, thanks to speakers placed around the TV.
  • Q-Symphony
    Transform your home into a majestic concert hall with perfectly orchestrated sound. Q-symphony technology synchronizes all the Neo QLED TV's speakers with the Q-Series 2022 sound bars. They operate simultaneously for an enhanced surround sound effect.
Samsung QE32LS03BBU The Frame LS03B Series - 32" LED-backlit LCD TV - QLED - Full HD
LED-backlit LCD TV - QLED - Smart TV
Diagonal Class
32"
Charcoal black
Platform
Tizen OS
Resolution
1920 x 1080
Display Format
1080p
HDR Technology
Hybrid Log-Gamma (HLG)
Frame Rate & Enhancement Technology
1100 Picture Quality Index, 50 Hz Refresh Rate
Video Interface
HDMI
HDMI Ports Qty
2 ports
Wi-Fi, Bluetooth
LCD Backlight Technology
LED backlight - Quantum Dot technology Micro Dimming Pro
Image Aspect Ratio
16:9
TV Tuner
1x analogue, 1x digital
Digital TV Tuner
DVB-C, DVB-S2, DVB-T2
Internet Streaming Services
Smart Hub, HbbTV 2.0.3
Picture Enhancements
HyperReal Engine, Mega Contrast, contrast enhancer, 100% Color Volume, AI Upscale, Wide Viewing Angle, One Billion Colour
Speaker System
2 channel
Sound Effects
Dolby Digital MS12
Platform
SmartThings
Intelligent Assistant
Alexa, Bixby, Google Assistant (not available for some languages and countries)
USB
2 ports
Samsung TM2280E remote control
Voltage
AC 220-240 V (50/60 Hz)
Energy Class
Class G
33 Watt
Power Consumption Stand by
0.5 Watt
72.89 cm x 2.47 cm x 41.94 cm
5.3 kg
1-year warranty
Energy Class
Class G
Energy Class (HDR)
Class G
Power Consumption (Max)
55 Watt
33 Watt
33 kWh/1000h
Power Consumption HDR (On mode)
50 kWh/1000h
Diagonal Class
32"
Series
Model Year
2022
Platform
Tizen OS
Operating System
Tizen OS
HDR Capable
HDR Technology
TV Tuner
TV Tuner Presence
Sensors
Eco Sensor, brightness sensor, motion sensor
Video Interface
HDMI
HDMI Ports Qty
2 ports
Modes
Cinema mode, Eye Comfort Mode, Art Mode, Decor Mode, HGIG Mode
Design
Very Narrow Bezel Design (VNB)
Dimensions
Without stand
72.89 cm
2.47 cm
41.94 cm
5.3 kg
Enclosure Colour
Charcoal black
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight - Quantum Dot technology - Micro Dimming Pro
Coating
Anti-glare
Display Menu Language
Multilingual
Auto Motion Plus, Smart Calibration, E-Manual, Multi View, Instant On, Customizable Frame, Brightness/Colour Detection, Wireless Dex
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Stand Colour
Grey
Flat Panel Mount Interface
VESA Compatibility
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
HDTV Tuner
Digital TV Service
HbbTV
Video Features
Teletext
Electronic Programme Guide
Digital EPG
Media Player
USB Port
USB Ports Qty
2
Remote Control
Remote control
Remote Control Model
Samsung TM2280E
Samsung Smart Control included
Audio System
Digital Audio Format
Dolby Digital Plus output
Sound Effects
Dolby Digital MS12
Speaker System
2 channel
Output Power / Total
20 Watt
Bluetooth Audio Streaming, Audio Return Channel (ARC), Audio Pre-selection Descriptor, Adaptive Sound, Object Tracking Sound, Q-Symphony, Object Tracking Sound Lite, Dual Audio support
Network & Internet Multimedia
Functionality
WEB browsing, Internet video playback
Wi-Fi, Bluetooth
Wi-Fi Protocol
802.11ac
Bluetooth Version
Bluetooth 5.2
Connect & Share
Wi-Fi Direct, Screen Mirroring, USB Human Interface Device (HID), ConnectShare, Bluetooth Human Interface Device (HID), Sound Mirroring, Media Home
Supported Consumer Electronics Control (CEC)
Anynet Plus, Multiroom Link
Application Store
Art Store
DLNA
Connector Type
2 x HDMI , 2 x USB , Digital audio output (optical) , One Connect Mini
Internet of Things (IoT)
Platform
SmartThings
Alexa, Bixby, Google Assistant built-in (not available for some languages and countries)
HGiG, IPv6
Power supply
Input Voltage
0.5 Watt
Auto On/Off
Auto power off
Limited warranty - 1 year
Dimensions & Weight Details
Panel without stand - 72.89 cm x 2.47 cm x 41.94 cm x 5.3 kg , Panel with stand - 72.89 cm x 14.3 cm x 45.2 cm x 5.4 kg
Width (Shipping)
81.5 cm
Depth (Shipping)
12.2 cm
Height (Shipping)
51.3 cm
Weight (Shipping)
7.9 kg
