Samsung 32" Black LED Large Format Display, Full HD, 400 cd/m2, 24/7
Quicklinx: D4NQWS00 Mfr#: LH32PMFPBGC/EN
TV Tuner Presence: No
Video Interface: HDMI
  • 1080p (Full HD)
£505.13 ex VAT
£606.15 inc VAT
Samsung PMF series displays ensure the digital signage is optimized for peak performance in a chic, captivating design. By delivering high brightness, sharp display images in various lighting environments with solid reliability for extended periods of time, businesses are assured their messaging is delivered exactly when and where it is needed. These displays deliver 24/7 robust durability for uninterrupted and dependable operation.
Samsung PM32F PMF Series - 32" LED display
LED-backlit LCD flat panel display
Diagonal Class
32"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Frame Rate & Enhancement Technology
60 Hz Refresh Rate
Video Wall Components Qty
225
Video Interface
HDMI
HDMI Ports Qty
2 ports
Wi-Fi
PC Interface
DVI, VGA (HD-15), DisplayPort
LCD Backlight Technology
LED backlight - edge-lit
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Button lock, HTML5 support, Auto Source Switching & Recovery
Speaker System
2 speakers
Storage Drive Capacity
8 GB
Remote Control
Standard remote
Energy Class
Class C
88 Watt
Power Consumption (On mode)
61 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
85 kWh
72.12 cm x 2.99 cm x 41.56 cm
5.6 kg
Energy Class
Class C
88 Watt
61 W
85 kWh
Diagonal Class
32"
Commercial Use
Series
PMF Series
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Temperature sensor
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
Modes
Portrait mode, landscape mode
Design
Narrow Bezel Design, swivel screen
Protection
Dustproof
225
Dimensions
Without stand
72.12 cm
2.99 cm
41.56 cm
5.6 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
60 Hz Refresh Rate
Image Contrast Ratio
5000:1
Brightness
400 cd/m²
Viewing Angle
178°
Viewing Angle (Vertical)
178°
Response Time
8 ms
Commercial Features
Operation Hours / Days
16 / 7
Multiple Display Control (MDC), MagicInfo, USB Cloning, Mega Dynamic Contrast Ratio, Certified for 16/7 Continuous Operation, SSSP 4.0, Center IR
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
200 x 200 mm
Media Player
8 GB
Operating System
Tizen OS
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
Wi-Fi
Connector Type
2 x HDMI , 2 x USB , DVI-I , Audio line-in , Audio line-out , DisplayPort input , DisplayPort output , Multiple Display Control , Serial input , Serial output
Batteries
Serial adapter
Plug and Play, CSA, UL, TUV, VCCI, C-Tick, BSMI, GOST, cUL, NEMKO, NOM, SASO, CB, AS/NZS 60950-1, CCC, PSB, IRAM, EN 60950-1, FCC Part 15 B Class A, KC, GB 9254-2008, NOM-019-SCFI-1998, KN22, KN24, K60950-1, cUL No.60950-1, EAC, GB4943.1-2011, RCM, IP5X, EN55024:1998 + A1:2001 + A2:2003, IS13252, VCCI V-3/2010.04 Class A, CNS 14972, GOST-R 51317 series, GOST 22505-97, CNS 13438 Class A ITE EMI, CNS 13439 AV EMI, CNS 14409 AV EMS, GB 17625.1-2012, NOM-001-SCFI-1993, BIS, INMETRO, IEC60950-1, CE/EMC, AS/NZS CISPR 22:2009, KCC/EK, EN55022:2006 + A1:2007
Power supply
0.5 Watt
Power Consumption (Off Mode)
0 Watt
Width (Shipping)
79.6 cm
Depth (Shipping)
13.2 cm
Height (Shipping)
48.4 cm
Weight (Shipping)
7 kg
10 - 80% (non-condensing)
Brand: Samsung
Price Range Ex VAT: 500 - 750
