Your basket is empty
Samsung 32" 1920x1080 DVI HDMI LED-backlit LCD Large Format Display
Quicklinx: 9KCWWS00 Mfr#: LH32DMDPLGC/EN
TV Tuner Presence: No
Video Interface: HDMI
  • 1080p (Full HD)
£432.94 ex VAT
£519.52 inc VAT
The Samsung DM32D delivers 24/7 reliability for continuous operation. Create stunning and seamless video walls in Full HD resolution thanks to an upgraded Samsung SMART Signage Platform (SSP) and full range of connectivity options. Combined with a sleek industrial design and slim 2" chassis depth, you can captivate your audience in a moment and leave a lasting impression on the 32" screen.
Samsung DM32D DM-D Series - 32" LED display
LED-backlit LCD flat panel display
Energy Class
Class C
77 Watt
Power Consumption (On mode)
60 W
Energy Consumption per Year
88 kWh
Diagonal Class
32"
Commercial Use
Yes - digital signage
72.14 cm x 4.99 cm x 42.03 cm
4.84 kg
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Component, composite, HDMI
HDMI Ports Qty
1 ports
Wi-Fi
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Supported Memory Cards
SD Memory Card
Remote Control
Standard remote
AC 120/230 V ( 50/60 Hz )
Environmental Standards
ENERGY STAR Qualified
Energy Class
Class C
77 Watt
60 W
88 kWh
Diagonal Class
32"
Commercial Use
Series
DM-D Series
TV Tuner
No tuner
Sensors
Temperature sensor
Video Interface
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Dimensions
Without stand
72.14 cm
4.99 cm
42.03 cm
4.84 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Coating
Super Clear
Colour Depth
Up to 1.07 billion colours
Dynamic Contrast Ratio
5000:1
Brightness
400 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.12125 x 0.36375mm
Response Time
8 ms
Commercial Features
Pivot, MagicInfo, LED BLU
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
200 x 200 mm
Media Player
SD Memory Card
Remote Control
Standard remote
Audio System
Built-in speaker
Network & Internet Multimedia
Wi-Fi
Connector Type
VGA input , DVI-D input , HDMI input , Audio line-in , Component video input , Composite video/audio input , Audio line-out
VGA cable
TUV, GOST, cUL, EN 60950, EN55022, NOM, PCBC, SASO, SIQ, IEC 60950, UL 60950, CB, CCC, EMC, PSB, EK, IRAM, K60950, NOM-001-SCFI-1993 IRAM, GB 4943.1, IS13252
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Width (Shipping)
80.1 cm
Depth (Shipping)
11.8 cm
Height (Shipping)
47 cm
Weight (Shipping)
5.9 kg
10 - 80%
9KCW Peerless-AV Peerless Universal Flat Wall Mount for 32" to 40" Displays In Stock £32.39
Brand: Samsung
Price Range Ex VAT: 300 - 500
