Samsung 3.8TB 883DCT SATA 2.5" SSD
Quicklinx: F8JLWS00 Mfr#: MZ-7LH3T8NE
Delivering optimized performance, a high quality of service and end-to-end data protection for servers that require enhanced data reliability.
Samsung's 883 DCT SSDs are an ideal solution for servers that need enhanced data reliability to safeguard critical data. From optimized performance and a high Quality of Service (QoS), to power-loss protection and end-to-end data protection, they deliver a highly reliable enterprise storage solution using the SATA interface.
Samsung 883 DCT MZ-7LH3T8NE - SSD - 3.8 TB - SATA 6Gb/s
Solid state drive - internal
3.8 TB
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
3D triple-level cell (TLC)
2.5"
SATA 6Gb/s
Buffer Size
4 GB
TRIM support, Auto Garbage Collection Algorithm, V-NAND Technology, Samsung MARU Controller, S.M.A.R.T.
69.85 mm x 100 mm x 6.8 mm
70 g
5-year warranty
3.8 TB
256-bit AES
2.5"
SATA 6Gb/s
Buffer Size
4 GB
69.85 mm
100 mm
6.8 mm
70 g
Performance
SSD Endurance
5466 TB
Data Transfer Rate Details
Serial ATA: 600 MB/s
Internal Data Rate
550 MBps (read) / 520 MBps (write)
Maximum 4KB Random Write
28000 IOPS
Maximum 4KB Random Read
98000 IOPS
Reliability
MTBF
2,000,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
2.5"
Power Consumption
3.6 Watt (read) , 2.3 Watt (write) , 1.3 Watt (idle max)
Software Included
Samsung SSD Magician DC
WWN
Limited warranty - 5 years
70 °C
Shock Tolerance (operating)
1500 g @ 0.5 ms half-sine
