Portability is the key element shared among all digital devices today where everything, including you, is constantly moving. When you are always on-the-go, your data should be, too. Born and bred with potent portability in its core, the Samsung Portable SSD T3 is built strong and light and is equipped with a built-in security feature. Most of all, it offers the blazing-fast data transfer speed of up to 450 MB/s. With compatibility across multiple operating systems and devices, the T3 will take your data to another level of accessibility.
Quick on its feet
Reduce downtime with blazing-fast, 450 MB/s read/write speeds, up to 4x faster than traditional external hard drives. -
Small, compact and light
A strong, shock-resistant metal case and internal support frame handles the daily wear of professional life, yet weighs is low and is roughly the size of a business card.
- Samsung T3 MU-PT2T0B - SSD - 2 TB - USB 3.1 Gen 1
- Solid state drive - external (portable)
- Capacity
- 2 TB
- Hardware Encryption
- Encryption Algorithm
- 256-bit AES
- Interface
- USB 3.1 Gen 1 - USB-C
- Data Transfer Rate
- 10.0 Gbps (USB 3.1) / 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
- Shock resistant, USB Attached SCSI Protocol (UASP) compliant, 256-bit AES
- Power Source
- USB bus
- 7.4 cm x 1.05 cm x 5.8 cm
- 51 g
- 3-year warranty
- Capacity
- 2 TB
- 256-bit AES
- Interface
- USB 3.1 Gen 1
- 7.4 cm
- 1.05 cm
- 5.8 cm
- 51 g
Performance
- Interface Transfer Rate
- Max Data Transfer Rate
- 450 MB/s
- SSD Endurance
- 400 TB
Expansion & Connectivity
- 1 x USB 3.1 Gen 1 - 24 pin USB-C
- Power Source
- USB bus
- OS Required
- Microsoft Windows 7 or later, Apple MacOS X 10.7 or later, Android 4.4 (KitKat) or later
- UL, TUV, VCCI, C-Tick, BSMI, CB, IC, FCC, KC, RoHS2, EAC
- Limited warranty - 3 years
