THE SAMSUNG SSD 860 EVO
The Samsung SSD 860 EVO is the newest of Samsung’s Client-PC SATA SSDs, specially designed for mainstream desktops and laptops. Building on the reputation of the Samsung SSD 850 EVO, the world’s first line of consumer SSDs with V-NAND 3bit MLC technology, the new Samsung SSD 860 EVO drives achieve industry-leading performance for SATA SSDs, offering improvements in speed, reliability, compatibility and capacity. The 860 EVO comes equipped with Samsung’s newly designed MJX controller along with the latest V-NAND architecture.
Enhanced Computing Experiences
The Samsung SSD 860 EVO is the newest of Samsung’s Client-PC SATA SSDs, specially designed for mainstream desktops and laptops. Building on the reputation of the Samsung SSD 850 EVO, the world’s first line of consumer SSDs with V-NAND 3bit MLC technology, the new Samsung SSD 860 EVO drives achieve industry-leading performance for SATA SSDs, offering improvements in speed, reliability, compatibility and capacity. The 860 EVO comes equipped with Samsung’s newly designed MJX controller along with the latest V-NAND architecture. Enhanced Computing Experiences The legacy Serial-ATA (SATA) interface faces the theoretical bandwidth limitation of 600MB/s which many SSD manufacturers have tried to reach over the years. Among them, Samsung, which first brought V-NAND technology to the market, continuously strives to improve product reliability and performance, even with the SATA interface limitations. Powered by Samsung’s latest V-NAND technology, the 860 EVO delivers top-notch sequential read (up to 550 MB/s) and write (up to 520 MB/s) speeds and along with high sustainable performance for everyday computing experiences. As the amount of data processing continuously increases, the need for faster data transfers and sustainable high performance over longer periods of time has become paramount in importance for users. To address this need, Samsung has newly introduced Intelligent TurboWrite technology. With this, the 860 EVO provides significantly accelerated write performance which is up to 6 times longer than that of the previous 850 EVO. Intelligent TurboWrite automatically decides how much space to allocate to the TurboWrite region in accordance with your system workload. So in a heavy workload situation, TurboWrite region will expand by up to 6 times versus that of the previous version of TurboWrite. helping to avoid sudden write performance drops which sometimes occur when performing large file transfer and ensuring that consumers enjoy the best write performance for longer than ever.
Worry-Free Reliability
The 860 EVO offers guaranteed endurance and unmatched reliability, with up to 6 times higher Total Bytes Written (TBW) than the previous 850 EVO and an industry-leading 5 year limited warranty. Up to 2,400 TBW powered by the latest V-NAND technology will give you absolute confidence in your SSD.(1)
Furthermore, the 860 EVO assures long-term dependable performance with minimal performance degradation. The 860 EVO provides up to 51% better sustained performance compare to that of its predecessor. This means you can fully experience the performance of the SSD even with heavy daily workload.
Expanded Compatibility with a Refined Controllee
The 860 EVO delivers expanded system compatibility. The refined ECC algorithm and revamped controller generate strong sustainable performance near SATA’s limits, and the improved queued trim provides for better Linux compatibility. Also the 860 EVO is available in 2.5-inch, mSATA, and M.2 form factors for a broad range of computing device.
Advanced Data Encryption
The 860 EVO provides multiple advanced data encryption features. Self-Encrypting Drive (SED) security technology will help keep data safe at all times. The 860 EVO includes an AES 256-bit hardware-based encryption engine to ensure that your personal files remain secure. Being hardware-based, the encryption engine secures your data without the performance degradation that you may experience with software-based encryption. Also, the 860 EVO is compliant with various advanced security management solutions (TCG Opal and Encrypted Drive-IEEE1667).
Samsung Data Migration and Magician Software
The 860 EVO comes with Samsung Data Migration and Magician Software, which is easy to install and makes management of you SSD simple. (2) Samsung Data Migration software is uncomplicated to use – yet provides a very powerful "Custom Cloning" feature that makes migration effortless even when the source data is greater than the SSD’s capacity. Magician provides personalized firmware checks and additional functions tailored for individual users’ drives. It even updates the firmware automatically to make sure that the drives’ performance stays up to date.
(1) All documented endurance test results are obtained in compliance with JESD218 standards. Please visit www.jedec.org for detailed standard information.
(2) To download Samsung Data Migration and Magician, please visit www.samsung.com/samsungssd
Samsung V-NAND technology
Samsung's V-NAND flash memory helps to overcome the limitations of conventional planar NAND architecture. It stacks 64 cell layers vertically over one another rather than trying to fit itself onto a fixed horizontal space, in order to provide high density and performance with a small footprint. -
Fast read/write performance
The 860 PRO performs at sequential write speeds up to 520 MB/s and sequential read speeds up to 550 MB/s with a robust a robust algorithm-based Samsung MJX controller (up to 1 GHz). -
Relentless endurance
The 860 PRO SSDs can consistently meet the needs of high-end use and heavy workloads with ease, such as safely storing and rendering 4K videos and 3D data. -
Expanded compatibility
Experience fast, fluid communication with your host system. The robust algorithm-based MJX controller generates high speeds, and the improved queued TRIM helps to enhance Linux compatibility. -
Robust SSD management software
Samsung Magician software is designed to help you manage your SSD with a simple and intuitive user interface. Get notifications when new firmware is released, and easily install updates for enhanced performance, stability and compatibility. And you can check your drive's sequential and random read/write speeds to benchmark performance. -
SSD data security
The drive includes an AES-256-bit hardware-based, full disk encryption engine that secures your data without sacrificing performance and is compliant with TCG/Opal and IEEE1667.
- Samsung 860 EVO MZ-76E2T0B - solid state drive - 2 TB - SATA 6Gb/s
- Solid state drive - internal - TRIM support, sleep mode, Auto Garbage Collection Algorithm, TurboWrite Technology, eDrive, Samsung MJX Controller, 3-bit 3D V-NAND Technology, Low Power DDR4 SDRAM Cache
- Capacity
- 2 TB
- Hardware Encryption
- Encryption Algorithm
- 256-bit AES
- NAND Flash Memory Type
- 3D multi-level cell (MLC)
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 2 GB
- TRIM support, sleep mode, Auto Garbage Collection Algorithm, TurboWrite Technology, eDrive, Samsung MJX Controller, 3-bit 3D V-NAND Technology, Low Power DDR4 SDRAM Cache, S.M.A.R.T., 256-bit AES, IEEE 1667
- 6.985 cm x 10 cm x 0.68 cm
- 62 g
- 5-year warranty
- Capacity
- 2 TB
- 256-bit AES
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 2 GB
- 6.985 cm
- 10 cm
- 0.68 cm
- 62 g
Performance
- SSD Endurance
- 1200 TB
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 550 MBps (read) / 520 MBps (write)
- 4KB Random Read
- 10000 IOPS
- 4KB Random Write
- 42000 IOPS
- Maximum 4KB Random Write
- 90000 IOPS
- Maximum 4KB Random Read
- 98000 IOPS
Reliability
- MTBF
- 1,500,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 2.5"
- Power Consumption
- 3 Watt (average) , 4 Watt (maximum)
- Software Included
- Samsung Magician Software
- WWN, IEEE 1667
- Limited warranty - 5 years
- 0 °C
- 70 °C
- Shock Tolerance (operating)
- 1500 g @ 0.5 ms half-sine
