Samsung 27" F591 Curved Display 1920 x 1080
Quicklinx: CBHMWS00 Mfr#: LC27F591FDUX/EN
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, VGA (HD-15)
£218.66 ex VAT
£262.39 inc VAT
The curvature of Samsung CF591 provides a truly immersive viewing experience that lets you enjoy big, bold and stunning panoramic views while you work or play. With its design inspired by the curve of the human eye, the Samsung CF591 monitor delivers a comfortable and enjoyable viewing experience for your home or office use. It boasts sleek curves and a stylish design that will compliment any room. Experience vibrant, stunningly vivid colors with Samsung's Active Crystal Color technology. The excellent 3000:1 contrast ratio delivers deeper blacks and brighter whites so you can clearly see even in an extremely dark or bright scene.
  • Immersive viewing experience with curved screen
    The 1800 R curvature of the screen provides a truly immersive viewing experience that lets you enjoy big, bold and stunning panoramic views while you work or play. With its design inspired by the curve of the human eye, the Samsung CF591 monitor delivers a comfortable and enjoyable viewing experience for your home or office use.
  • Sleek, curved design
    Featuring a glossy body and metallic finish, the Samsung CF591 monitor boasts sleek curves and a stylish design that will compliment any room. The simple, circular stand will help add an ultimate look to your work space.
  • Advanced gaming experience with AMD FreeSync
    AMD FreeSync technology allows users to enjoy smooth images, even during the fastest moving scenes. AMD FreeSync dynamically syncs the screen refresh rate with the frame rate of your content to minimize input latency and dramatically reduce image tearing and stutter during gaming. With its 4 ms response time, you'll see the ultra-fast on-screen motion clearly and smoothly with less motion blur, judder and ghosting. The fast response time provides a steady visual, allowing players to experience their games at the high level.
  • Built-in stereo speakers and multiple ports
    The powerful, built-in 5 W stereo speakers deliver full, rich sound for watching movies or playing games. The Samsung CF591 monitor comes with multiple ports including HDMI and DisplayPort to provide multiple options for connectivity. Enhance your computing experience by easily connecting to your PCs, game consoles, additional monitors and more.
  • Eye Saver mode
    Eye Saver mode optimizes your viewing comfort by reducing blue light emissions and flickers at the touch of a button. Read documents, play games, watch movies and edit photos for long periods of time, and experience a comfortable and pleasing view, without worrying about eye strain or fatigue.
  • Brilliant picture quality
Samsung C27F591FDU - CF591 Series - LED monitor - curved - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
54 kWh
Power Consumption (On mode)
37 W
Curved Screen
Adaptive-Sync Technology
AMD FreeSync
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.3113 mm
Brightness
250 cd/m²
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
White silver
61.42 cm x 27.04 cm x 45.73 cm
4.4 kg
DDC-2B, ISO 9241-307
Display Type
Energy Class
Class B
54 kWh
37 W
Diagonal Size
27"
Curved Screen
Yes (1800R)
AMD FreeSync
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.3113 mm
Brightness
250 cd/m²
Colour Support
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
MagicBright, game mode, Eco Saving, Mega Infinity Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Mercury free, Eye Saver Mode, Active Crystal Color
White silver
61.42 cm x 27.04 cm x 45.73 cm - with stand
4.4 kg
Audio
Speakers - stereo
Output Power / Channel
5 Watt
VGA , HDMI , DisplayPort , Audio line-in , Headphones
Mechanical
Tilt
1 x HDMI cable
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Apple MacOS, Windows 10
Dimensions & Weight Details
With stand - width: 61.42 cm - depth: 27.04 cm - height: 45.73 cm - weight: 4.4 kg , Without stand - width: 61.42 cm - depth: 14.29 cm - height: 36.29 cm
Samsung 27 Bundle deal on Samsung 27" F591 Curved Display 1920 x 1080
£317.83
Diagonal Size: 27in
Response Time: 4ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Samsung
Price Range Ex VAT: 150 - 300
