A modern take on a classic. The next generation Bar Plus elevates the flash drive to an everyday essential, offering impressive speed and striking design. Fit to your hand, the metal unibody is pure minimalism in a drive that cleverly blends style, speed, and reliability.
Get your time back. Fast and convenient read speeds up to 300 MB/s with the USB 3.1 standard give you more time to work, play, watch, and create. Send a 3GB 4K UHD video file from your Bar Plus to your PC in just 10 seconds.
- Samsung BAR Plus MUF-256BE4 - USB flash drive - 256 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.1 Gen 1
- Storage Capacity
- 256 GB
- Enclosure Colour
- Titan grey
- 5-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 256 GB
- Enclosure Colour
- Titan grey
- Read Rate
- Up to 300 MB/s
- Interface Type
- USB 3.1 Gen 1
- Shockproof, magnetic-proof, waterproof, X-ray-proof, temperature-proof, metal body, key ring loop
- Limited warranty - 5 years
- 15.46 mm
- 12 mm
- 40 mm
- 11.5 g
- 0 °C
- 60 °C
