Samsung 256GB Bar Plus USB 3.1 Drive - Titan Grey
Quicklinx: DRNQWS00 Mfr#: MUF-256BE4/EU
Select:
  • 256GB
A modern take on a classic. The next generation Bar Plus elevates the flash drive to an everyday essential, offering impressive speed and striking design. Fit to your hand, the metal unibody is pure minimalism in a drive that cleverly blends style, speed, and reliability.
Get your time back. Fast and convenient read speeds up to 300 MB/s with the USB 3.1 standard give you more time to work, play, watch, and create. Send a 3GB 4K UHD video file from your Bar Plus to your PC in just 10 seconds.
Samsung BAR Plus MUF-256BE4 - USB flash drive - 256 GB
USB flash drive
Interface Type
USB 3.1 Gen 1
Storage Capacity
256 GB
Enclosure Colour
Titan grey
5-year warranty
USB flash drive
Storage Capacity
256 GB
Enclosure Colour
Titan grey
Read Rate
Up to 300 MB/s
Interface Type
USB 3.1 Gen 1
Shockproof, magnetic-proof, waterproof, X-ray-proof, temperature-proof, metal body, key ring loop
Limited warranty - 5 years
15.46 mm
12 mm
40 mm
11.5 g
60 °C
