Samsung 256GB Bar Plus USB 3.1 Drive - Champagne Silver
Quicklinx: DRNKWS00 Mfr#: MUF-256BE3/EU
Capacity: 256GB
Interface: USB 3.1 Gen 1
More than 50 in stock
£43.74 ex VAT
£52.48 inc VAT
A modern take on a classic. The next generation Bar Plus elevates the flash drive to an everyday essential, offering impressive speed and striking design. Fit to your hand, the metal unibody is pure minimalism in a drive that cleverly blends style, speed, and reliability.
Get your time back. Fast and convenient read speeds up to 300 MB/s with the USB 3.1 standard give you more time to work, play, watch, and create. Send a 3GB 4K UHD video file from your Bar Plus to your PC in just 10 seconds.
  • Speed in style
  • Move files in a flash
  • Rugged refinement
    As strong as it is stylish. The sturdy metal body keeps your data safe and intact, and the integrated keyring prevents accidental misplacement or loss. The Bar Plus is the ideal combination of stunning design and worry-free durability.
Samsung BAR Plus MUF-256BE3 - USB flash drive - 256 GB
USB flash drive
Interface Type
USB 3.1 Gen 1
Storage Capacity
256 GB
Enclosure Colour
Champagne silver
5-year warranty
USB flash drive
Storage Capacity
256 GB
Enclosure Colour
Champagne silver
Compatibility
Non-specific
Read Rate
Up to 300 MB/s
Interface Type
USB 3.1 Gen 1
Shockproof, magnetic-proof, waterproof, X-ray-proof, temperature-proof, metal body, key ring loop
Limited warranty - 5 years
15.46 mm
12 mm
40 mm
11.5 g
60 °C
Capacity: 256GB
Brand: Samsung
Price Range Ex VAT: 0 - 50
